j'essaie de faire fonctionner un dac audio i2s (GY-PCM5102) sur mon raspberry,
j'ai suivi le tuto suivant :
https://support.hifiberry.com/hc/en-us/ ... -or-higher
avec les branchement suivant :
la carte semble bien détectée :SCK > Not wired (Internally generated)
BCK > PIN 12 (GPIO18)
DIN > PIN 40 (GPIO21)
LRCK > PIN 35 (GPIO19)
GND > PIN 6 (GND)
VIN > PIN 2 (3.3V)
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
You have new mail in /var/mail/daguhh
mplayer 01\ Adele\ -\ Rolling\ in\ the\ Deep.wav
MPlayer 1.3.0 (Debian), built with gcc-6.2.1 (C) 2000-2016 MPlayer Team
do_connect: could not connect to socket
connect: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing 01 Adele - Rolling in the Deep.wav.
libavformat version 57.56.101 (external)
Mismatching header version 57.56.100
libavformat file format detected.
[lavf] stream 0: audio (pcm_s16le), -aid 0
Clip info:
title: Rolling in the Deep
artist: Adele
album: 21
genre: Soul and R&B
iaar: Adele
track: 1
itgl: -972
irva: 99
iagl: -993
ITOC: B+96+43C3+852C+CE74+115B4+15C83+1ADF1+1F0CD+23799+29D99+2FA42+34E80
Load subtitles in ./
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 44100 Hz, 2 ch, s16le, 1411.2 kbit/100.00% (ratio: 176400->176400)
Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
AO: [pulse] Init failed: Connection refused
Failed to initialize audio driver 'pulse'
[AO_ALSA] alsa-lib: pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM false
[AO_ALSA] Playback open error: No such file or directory
Failed to initialize audio driver 'alsa'
[AO SDL] Samplerate: 44100Hz Channels: Stereo Format s16le
[AO SDL] using aalib audio driver.
[AO SDL] Unable to open audio: No available audio device
Failed to initialize audio driver 'sdl:aalib'
Could not open/initialize audio device -> no sound.
Audio: no sound
Video: no video
[ 11.110561] snd-hifiberry-dac soc:sound: ASoC: CPU DAI (null) not registered - will retry
[ 11.113935] snd-hifiberry-dac soc:sound: ASoC: CODEC DAI pcm5102a-hifi not registered - will retry
[ 11.132580] snd-hifiberry-dac soc:sound: pcm5102a-hifi <-> 3f203000.i2s mapping ok
[ 11.482918] smsc95xx 1-1.1:1.0 enxb827eba4b8a8: renamed from eth0
[ 11.533383] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 11.553512] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 11.560113] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[ 11.560375] usbcore: registered new interface driver brcmfmac
[ 12.040005] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[ 12.040780] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[ 14.635787] uart-pl011 3f201000.serial: no DMA platform data
[ 18.119926] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k FS
[ 19.837018] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 19.837129] brcmfmac: power management disabled
[ 20.243835] smsc95xx 1-1.1:1.0 enxb827eba4b8a8: hardware isn't capable of remote wakeup
