http://www.arcadeworlduk.com/products/1 ... -No10.html
Le site indique :
Mais aussi :The arcade controller included in this kit is compatible with PC & PS3 and comes complete with a pre-crimped wiring harness for easy connection. There is absolutely no soldering required - Simply plug and play. The arcade controller PCB is detected by your computer as a simple gamepad, unlike the I-PAC PCBs, which are keyboard encoders.
Le kernel 3.12 de rasbian est il supérieur à une version de kernel 3.2 ?This boards does not with Linux kernel greater than ver. 3.2
Quelle est la version de kernel du linux qui va héberger piplay ?
Je suis aussi preneur d'une solution alternative moins chère, et/ou moins galère !
Merci.
