probleme config wifi
pouypouy
Message par pouypouy » jeu. 12 nov. 2015 22:18
SUite a des problemes de connexion avec ma franboise j'ai ré installer un nouveau raspbian tout beau tout neuf et tenté de configurer ma connexion wifi sans succes....
lsusb donne
pi@raspberrypi ~ $ lsusb
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
et
sudo nano /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid **************************
wpa-psk *************
aucune connexion
Si je fait un ifconfig:
pi@raspberrypi ~ $ ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:fc:01:1f
          inet adr:192.168.0.18  Bcast:192.168.0.255  Masque:255.255.255.0
          adr inet6: fe80::ba27:ebff:fefc:11f/64 Scope:Lien
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:3050 errors:0 dropped:5 overruns:0 frame:0
          TX packets:1954 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:1000
          RX bytes:222144 (216.9 KiB)  TX bytes:190134 (185.6 KiB)
lo        Link encap:Boucle locale
          inet adr:127.0.0.1  Masque:255.0.0.0
          adr inet6: ::1/128 Scope:Hôte
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr 80:1f:02:af:45:7f
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:67 overruns:0 frame:0
Si vous aves des idees...
darkprocess75
Re: probleme config wifi
Message par darkprocess75 » jeu. 12 nov. 2015 23:28
Bonsoir. Enlever la ligne allow hotplug wlan0 et mettre auto wlan0 dans /etc/network/interfaces
pouypouy
Message par pouypouy » ven. 13 nov. 2015 08:02
salut,
apres modif et reboot pas mieux.
pi@raspberrypi ~ $
          RX packets:153 errors:0 dropped:0 overruns:0 frame:0
          TX packets:146 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:14155 (13.8 KiB)  TX bytes:21829 (21.3 KiB)
          adr inet6: fe80::8fb4:1243:8fe5:2154/64 Scope:Lien
          RX packets:0 errors:0 dropped:7 overruns:0 frame:0
darkprocess75
Message par darkprocess75 » ven. 13 nov. 2015 20:05
darkprocess75
Message par darkprocess75 » ven. 13 nov. 2015 20:52
Le fichier wpa-supplicant.conf est il renseigné avec le nom du reseau wifi?
pouypouy
Message par pouypouy » ven. 13 nov. 2015 21:20
concernant le fichier wpa supplicant, son contenu:
update_config=1
network={
        ssid="*************"
        psk="***********"
        key_mgmt=WPA-PSK
bien sur le ssid et le code ont été vérifié plusieurs fois ;-)
pouypouy
Message par pouypouy » ven. 13 nov. 2015 21:34
j'ai tenter mais sans résultat, suite a cela:
          adr inet6: fe80::1a8f:44b0:654d:ff1a/64 Scope:Lien
          RX packets:1634 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1096 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:97701 (95.4 KiB)  TX bytes:77417 (75.6 KiB)
          RX packets:200 errors:0 dropped:0 overruns:0 frame:0
          TX packets:200 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:16656 (16.2 KiB)  TX bytes:16656 (16.2 KiB)
          RX packets:0 errors:0 dropped:43 overruns:0 frame:0
ou encore :
pi@raspberrypi ~ $ iwconfig
wlan0     unassociated  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
lo        no wireless extensions.
eth0      no wireless extensions.
darkprocess75
Message par darkprocess75 » ven. 13 nov. 2015 22:46
network={
ssid="YOUR_NETWORK_NAME"
psk="YOUR_NETWORK_PASSWORD"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
darkprocess75
Message par darkprocess75 » ven. 13 nov. 2015 22:48
Pouvez vous modifier le wpa supplicant avec les ajouts ci-dessus.
pouypouy
Message par pouypouy » ven. 13 nov. 2015 22:58
salut, et merci pour l'aide!!
Toujours pareil malgré ces modifs.
