Depuis quelques temps, impossible de faire des mises à jour ou installer de nouvelles choses via apt-get. Je vous copie le message d'erreur qui sera, je pense, plus parlant pour vous. Si quelqu'un pouvait m'aider à résoudre ce problème qui est très gênant, ça serait sympa.
Setting up multiarch-support (2.13-38+rpi2+deb7u10) ...
dpkg: warning: files list file for package 'liblinear1' missing; assuming package has no files currently installed
dpkg: warning: files list file for package 'libfm-modules:armhf' missing; assuming package has no files currently installed
dpkg: warning: files list file for package 'libopencv-video2.4' missing; assuming package has no files currently installed
dpkg: warning: files list file for package 'hicolor-icon-theme' missing; assuming package has no files currently installed
dpkg: warning: files list file for package 'libwildmidi1:armhf' missing; assuming package has no files currently installed
(Reading database ... 83402 files and directories currently installed.)
Preparing to replace samba 2:3.6.6-6+deb7u5 (using .../samba_2%3a3.6.6-6+deb7u7_armhf.deb) ...
Unpacking replacement samba ...
syntax error at /usr/sbin/update-inetd line 115, near ") {"
Unrecognized character \xA8; marked by <-- HERE after st = stlit<-- HERE near column 20 at /usr/sbin/update-inetd line 116.
dpkg: warning: subprocess old post-removal script returned error exit status 255
dpkg: trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/samba_2%3a3.6.6-6+deb7u7_armhf.deb (--unpack):
subprocess new post-removal script returned error exit status 255
dpkg: error while cleaning up:
Preparing to replace libwbclient0:armhf 2:3.6.6-6+deb7u6 (using .../libwbclient0_2%3a3.6.6-6+deb7u7_armhf.deb) ...
Unpacking replacement libwbclient0:armhf ...
Preparing to replace smbclient 2:3.6.6-6+deb7u6 (using .../smbclient_2%3a3.6.6-6+deb7u7_armhf.deb) ...
Unpacking replacement smbclient ...
Preparing to replace samba-common 2:3.6.6-6+deb7u6 (using .../samba-common_2%3a3.6.6-6+deb7u7_all.deb) ...
Unpacking replacement samba-common ...
Processing triggers for man-db ...
fopen: Not a directory
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
