Re: Base de donne kodi
Posté : ven. 3 avr. 2015 09:56
je fait comment hihi ?
Les forums français du Raspberry Pi
http://forums.framboise314.fr/
17:34:38 T:3023618048 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:34:38 T:3023618048 NOTICE: -----------------------------------------------------------------------
17:34:38 T:3023618048 NOTICE: Starting Kodi (14.1 Git:Unknown). Platform: Linux ARM 32-bit
17:34:38 T:3023618048 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
17:34:38 T:3023618048 NOTICE: Kodi compiled Mar 14 2015 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
17:34:38 T:3023618048 NOTICE: Running on Open Source Media Center 0.9.9, kernel: Linux ARM 32-bit version 3.18.9-3-osmc
17:34:38 T:3023618048 NOTICE: FFmpeg statically linked, version: 6be3e39-xbmc-2.4.6-Helix
17:34:38 T:3023618048 NOTICE: Host CPU: ARMv6-compatible processor rev 7 (v6l), 1 core available
17:34:38 T:3023618048 NOTICE: ARM Features: Neon disabled
17:34:38 T:3023618048 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
17:34:38 T:3023618048 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
17:34:38 T:3023618048 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
17:34:38 T:3023618048 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
17:34:38 T:3023618048 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
17:34:38 T:3023618048 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
17:34:38 T:3023618048 NOTICE: Local hostname: osmc
17:34:38 T:3023618048 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
17:34:38 T:3023618048 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
17:34:39 T:3023618048 NOTICE: load settings...
17:34:40 T:3023618048 NOTICE: Found 1 Lists of Devices
17:34:40 T:3023618048 NOTICE: Enumerated PI devices:
17:34:40 T:3023618048 NOTICE: Device 1
17:34:40 T:3023618048 NOTICE: m_deviceName : HDMI
17:34:40 T:3023618048 NOTICE: m_displayName : HDMI
17:34:40 T:3023618048 NOTICE: m_displayNameExtra:
17:34:40 T:3023618048 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
17:34:40 T:3023618048 NOTICE: m_channels : FL,FR
17:34:40 T:3023618048 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
17:34:40 T:3023618048 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
17:34:40 T:3023618048 NOTICE: Device 2
17:34:40 T:3023618048 NOTICE: m_deviceName : Analogue
17:34:40 T:3023618048 NOTICE: m_displayName : Analogue
17:34:40 T:3023618048 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:34:40 T:3023618048 NOTICE: m_sampleRates : 48000
17:34:40 T:3023618048 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
17:34:40 T:3023618048 NOTICE: Device 3
17:34:40 T:3023618048 NOTICE: m_deviceName : Both
17:34:40 T:3023618048 NOTICE: m_displayName : HDMI and Analogue
17:34:40 T:3023618048 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
17:34:40 T:3023618048 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<network>
<readbufferfactor>4.0</readbufferfactor>
</network>
<imageres>540</imageres>
<fanartres>720</fanartres>
<splash>false</splash>
</advancedsettings>
17:34:40 T:3023618048 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:34:40 T:3023618048 NOTICE: Default DVD Player: dvdplayer
17:34:40 T:3023618048 NOTICE: Default Video Player: dvdplayer
17:34:40 T:3023618048 NOTICE: Default Audio Player: paplayer
17:34:40 T:3023618048 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:34:40 T:3023618048 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:34:40 T:3023618048 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:34:40 T:3023618048 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:34:40 T:3023618048 NOTICE: Loaded playercorefactory configuration
17:34:40 T:3023618048 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:34:40 T:3023618048 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:34:50 T:3023610912 NOTICE: Thread ActiveAE start, auto delete: false
17:34:50 T:3013604384 NOTICE: Thread AESink start, auto delete: false
17:34:50 T:2952786976 NOTICE: Thread CRBPWorker start, auto delete: false
17:34:50 T:3023618048 NOTICE: Running database version Addons16
17:34:52 T:3023618048 NOTICE: ADDONS: Using repository repository.xbmc.org
17:34:52 T:3023618048 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
17:34:52 T:2944398368 NOTICE: Thread CECAdapter start, auto delete: false
17:34:52 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:52 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:34:52 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 1)
17:34:52 T:2936009760 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
17:34:53 T:3023618048 NOTICE: Raspberry PI firmware version: Mar 3 2015 15:29:03
Copyright (c) 2012 Broadcom
version 4b55b3e95322381c9964fa6576476cd933f678a4 (clean) (release)
17:34:53 T:3023618048 NOTICE: ARM mem: 368MB GPU mem: 144MB MPG2:0 WVC1:0
17:34:53 T:3023618048 NOTICE: cacheMemBufferSize: 20MB
17:34:53 T:3023618048 NOTICE: Config:
arm_freq=1000
avoid_fix_ts=1
config_hdmi_boost=2
core_freq=450
disable_commandline_tags=2
disable_overscan=1
emmc_pll_core=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
over_voltage=6
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
temp_limit=85
device_tree=-
17:34:53 T:3023618048 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
17:34:53 T:3023618048 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480i @ 60.000000 Hz
17:34:53 T:3023618048 NOTICE: Found (720x480i@60.000000) at 16, setting to RES_DESKTOP at 16
17:34:53 T:3023618048 NOTICE: Checking resolution 16
17:34:53 T:3023618048 NOTICE: GL_VENDOR = Broadcom
17:34:53 T:3023618048 NOTICE: GL_RENDERER = VideoCore IV HW
17:34:53 T:3023618048 NOTICE: GL_VERSION = OpenGL ES 2.0
17:34:53 T:3023618048 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
17:34:53 T:3023618048 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
17:34:53 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:53 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:34:53 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 2)
17:34:54 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:54 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:34:54 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 3)
17:34:55 T:3023618048 NOTICE: Running database version Addons16
17:34:55 T:3023618048 NOTICE: Running database version ViewModes6
17:34:55 T:3023618048 NOTICE: Running database version Textures13
17:34:55 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:55 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:34:55 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 4)
17:34:55 T:3023618048 NOTICE: Running database version MyMusic48
17:34:55 T:3023618048 NOTICE: Running database version MyVideos90
17:34:55 T:3023618048 NOTICE: Running database version TV26
17:34:55 T:3023618048 NOTICE: Running database version Epg8
17:34:55 T:3023618048 NOTICE: start dvd mediatype detection
17:34:56 T:2927182880 NOTICE: Thread DetectDVDMedia start, auto delete: false
17:34:56 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:56 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:34:56 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 5)
17:34:57 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:57 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:34:57 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 6)
17:34:58 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:58 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:34:58 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 7)
17:34:59 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:59 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:34:59 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 8)
17:35:00 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:35:00 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:35:00 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 9)
17:35:01 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:35:01 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:35:01 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 10)
17:35:02 T:2944398368 ERROR: CecLogMessage - could not start CEC communications
17:35:02 T:2944398368 ERROR: OpenConnection - could not opening a connection to the CEC adapter
17:35:04 T:3023618048 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
17:35:04 T:3023618048 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
17:35:04 T:3023618048 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
17:35:04 T:3023618048 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:35:04 T:2911945760 NOTICE: Thread LanguageInvoker start, auto delete: false
17:35:05 T:3023618048 NOTICE: Previous line repeats 4 times.
17:35:05 T:3023618048 NOTICE: initialize done
17:35:05 T:3023618048 NOTICE: Running the application...
17:35:05 T:2867852320 NOTICE: Thread JobWorker start, auto delete: true
17:35:07 T:2858939424 NOTICE: Thread LanguageInvoker start, auto delete: false
17:35:08 T:2850026528 NOTICE: Thread JobWorker start, auto delete: true
17:35:08 T:2841637920 NOTICE: Thread LanguageInvoker start, auto delete: false
17:35:08 T:3023618048 NOTICE: starting zeroconf publishing
17:35:08 T:3023618048 NOTICE: Webserver: Starting...
17:35:08 T:3023618048 NOTICE: WebServer: Started the webserver
17:35:08 T:3023618048 NOTICE: ES: Starting event server
17:35:08 T:2824860704 NOTICE: Thread JobWorker start, auto delete: true
17:35:08 T:2799694880 NOTICE: Thread EventServer start, auto delete: false
17:35:08 T:2799694880 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
17:35:08 T:2799694880 NOTICE: UDP: Listening on port 9777
17:35:08 T:2791306272 NOTICE: Thread TCPServer start, auto delete: false
17:35:09 T:2903557152 NOTICE: -->Python Interpreter Initialized<--
17:35:12 T:2944398368 NOTICE: Previous line repeats 6 times.
17:35:12 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:35:12 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:35:12 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 1)
17:35:13 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:35:13 T:2944398368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
17:35:13 T:2944398368 ERROR: CecLogMessage - could not open a connection (try 2)
17:35:14 T:2944398368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
17:34:40 T:3023618048 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)Code : Tout sélectionner
17:34:38 T:3023618048 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdataCode : Tout sélectionner
18:44:47 T:1957322752 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:44:47 T:1957322752 NOTICE: -----------------------------------------------------------------------
18:44:47 T:1957322752 NOTICE: Starting Kodi (14.2 Git:Unknown). Platform: Linux ARM (Thumb) 32-bit
18:44:47 T:1957322752 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
18:44:47 T:1957322752 NOTICE: Kodi compiled Apr 9 2015 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.7 (200711)
18:44:47 T:1957322752 NOTICE: Running on Open Source Media Center 0.9.9, kernel: Linux ARM 32-bit version 3.18.10-1-osmc
18:44:47 T:1957322752 NOTICE: FFmpeg statically linked, version: 2.4.6-xbmc-2.4.6-Helix
18:44:47 T:1957322752 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
18:44:47 T:1957322752 NOTICE: ARM Features: Neon enabled
18:44:47 T:1957322752 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
18:44:47 T:1957322752 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
18:44:47 T:1957322752 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
18:44:47 T:1957322752 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
18:44:47 T:1957322752 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
18:44:47 T:1957322752 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
18:44:47 T:1957322752 NOTICE: Local hostname: osmc
18:44:47 T:1957322752 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
18:44:47 T:1957322752 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
18:44:47 T:1957322752 NOTICE: load settings...
18:44:48 T:1957322752 NOTICE: Found 1 Lists of Devices
18:44:48 T:1957322752 NOTICE: Enumerated PI devices:
18:44:48 T:1957322752 NOTICE: Device 1
18:44:48 T:1957322752 NOTICE: m_deviceName : HDMI
18:44:48 T:1957322752 NOTICE: m_displayName : HDMI
18:44:48 T:1957322752 NOTICE: m_displayNameExtra:
18:44:48 T:1957322752 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:44:48 T:1957322752 NOTICE: m_channels : FL,FR
18:44:48 T:1957322752 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
18:44:48 T:1957322752 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
18:44:48 T:1957322752 NOTICE: Device 2
18:44:48 T:1957322752 NOTICE: m_deviceName : Analogue
18:44:48 T:1957322752 NOTICE: m_displayName : Analogue
18:44:48 T:1957322752 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:44:48 T:1957322752 NOTICE: m_sampleRates : 48000
18:44:48 T:1957322752 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
18:44:48 T:1957322752 NOTICE: Device 3
18:44:48 T:1957322752 NOTICE: m_deviceName : Both
18:44:48 T:1957322752 NOTICE: m_displayName : HDMI and Analogue
18:44:48 T:1957322752 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
18:44:48 T:1957322752 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<advancedsettings>
<network>
</network>
</advancedsettings>
18:44:48 T:1957322752 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:44:48 T:1957322752 NOTICE: Default DVD Player: dvdplayer
18:44:48 T:1957322752 NOTICE: Default Video Player: dvdplayer
18:44:48 T:1957322752 NOTICE: Default Audio Player: paplayer
18:44:48 T:1957322752 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:44:48 T:1957322752 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:44:48 T:1957322752 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:44:48 T:1957322752 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:44:48 T:1957322752 NOTICE: Loaded playercorefactory configuration
18:44:48 T:1957322752 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:44:48 T:1957322752 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:44:50 T:1957315616 NOTICE: Thread ActiveAE start, auto delete: false
18:44:50 T:1947202592 NOTICE: Thread AESink start, auto delete: false
18:44:50 T:1886385184 NOTICE: Thread CRBPWorker start, auto delete: false
18:44:50 T:1957322752 NOTICE: Running database version Addons16
18:44:51 T:1957322752 NOTICE: ADDONS: Using repository repository.xbmc.org
18:44:51 T:1957322752 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
18:44:51 T:1875416096 NOTICE: Thread CECAdapter start, auto delete: false
18:44:51 T:1846539296 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
18:44:51 T:1957322752 NOTICE: Raspberry PI firmware version: Apr 6 2015 13:30:31
version 52e98d667b8b6ef27a2df8d817807701057bb30d (clean) (release)
18:44:51 T:1957322752 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
18:44:51 T:1957322752 NOTICE: cacheMemBufferSize: 20MB
18:44:51 T:1957322752 NOTICE: Config:
arm_control=0xa5800010
arm_freq=1000
avoid_fix_ts=1
config_hdmi_boost=2
core_freq=500
disable_l2cache=1
disable_overscan=1
emmc_pll_core=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_swap=1
hdmi_channel_map=8
ignore_lcd=1
over_voltage=2
over_voltage_avs=0x1b774
sdram_freq=500
sdtv_aspect=1
temp_limit=85
device_tree=-
18:44:51 T:1957322752 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
18:44:51 T:1957322752 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
18:44:51 T:1957322752 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
18:44:51 T:1957322752 NOTICE: Found (1280x720@60.000000) at 20, setting to RES_DESKTOP at 16
18:44:51 T:1957322752 NOTICE: Checking resolution 16
18:44:51 T:1957322752 NOTICE: GL_VENDOR = Broadcom
18:44:51 T:1957322752 NOTICE: GL_RENDERER = VideoCore IV HW
18:44:51 T:1957322752 NOTICE: GL_VERSION = OpenGL ES 2.0
18:44:51 T:1957322752 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:44:51 T:1957322752 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
18:44:51 T:1957322752 NOTICE: Running database version Addons16
18:44:51 T:1957322752 NOTICE: Running database version ViewModes6
18:44:51 T:1957322752 NOTICE: Running database version Textures13
18:44:51 T:1957322752 NOTICE: Running database version MyMusic48
18:44:51 T:1957322752 NOTICE: Running database version MyVideos90
18:44:51 T:1957322752 NOTICE: Running database version TV26
18:44:51 T:1957322752 NOTICE: Running database version Epg8
18:44:51 T:1957322752 NOTICE: start dvd mediatype detection
18:44:51 T:1866535968 NOTICE: Thread DetectDVDMedia start, auto delete: false
18:45:01 T:1957322752 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
18:45:01 T:1957322752 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
18:45:01 T:1957322752 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
18:45:01 T:1957322752 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:45:02 T:1822733344 NOTICE: Thread LanguageInvoker start, auto delete: false
18:45:02 T:1772401696 NOTICE: Previous line repeats 5 times.
18:45:02 T:1772401696 NOTICE: Thread JobWorker start, auto delete: true
18:45:02 T:1772401696 NOTICE: PVRManager - starting up
18:45:02 T:1763750944 NOTICE: Thread PVRManager start, auto delete: false
18:45:02 T:1755362336 NOTICE: Thread PVRClient start, auto delete: false
18:45:02 T:1957322752 NOTICE: initialize done
18:45:02 T:1957322752 NOTICE: Running the application...
18:45:02 T:1745400864 NOTICE: Thread CECAdapterUpdate start, auto delete: false
18:45:02 T:1789178912 NOTICE: -->Python Interpreter Initialized<--
18:45:02 T:1780790304 NOTICE: Previous line repeats 3 times.
18:45:02 T:1780790304 NOTICE: RCB Service: Start
18:45:02 T:1780790304 ERROR: EXCEPTION: Could not get AddonPtr given a script id of script.games.rom.collection.browser.If you are trying to use 'os.getcwd' to set the path, you cannot do that in a version 2.1.0 plugin.
18:45:02 T:1780790304 NOTICE: RCB Service: Error while accessing "script.games.rom.collection.browser". Make sure the addon is installed.
18:45:02 T:1780790304 NOTICE: RCB Service: Done
18:45:02 T:1814344736 NOTICE: -->Python Interpreter Initialized<--
18:45:03 T:1780790304 NOTICE: Previous line repeats 1 times.
18:45:03 T:1780790304 NOTICE: Thread JobWorker start, auto delete: true
18:45:03 T:1718961184 NOTICE: Thread LanguageInvoker start, auto delete: false
18:45:03 T:1957322752 NOTICE: Previous line repeats 1 times.
18:45:04 T:1957322752 NOTICE: starting zeroconf publishing
18:45:04 T:1700586528 NOTICE: Thread JobWorker start, auto delete: true
18:45:04 T:1957322752 NOTICE: Webserver: Starting...
18:45:04 T:1957322752 ERROR: WebServer: Failed to start the webserver
18:45:04 T:1957322752 NOTICE: ES: Starting event server
18:45:04 T:1692197920 NOTICE: Thread EventServer start, auto delete: false
18:45:04 T:1692197920 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:45:04 T:1692197920 NOTICE: UDP: Listening on port 9777
18:45:04 T:1683809312 NOTICE: Thread TCPServer start, auto delete: false
18:45:04 T:1675420704 NOTICE: Thread JobWorker start, auto delete: true
18:45:04 T:1755362336 NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 224 channels.
18:45:08 T:1718961184 NOTICE: -->Python Interpreter Initialized<--
18:45:11 T:1797567520 NOTICE: Previous line repeats 1 times.
18:45:11 T:1797567520 NOTICE: script.grab.fanart: Grab Fanart Service Started
18:45:17 T:1728365600 NOTICE: Thread PVRGUIInfo start, auto delete: false
18:45:20 T:1718961184 NOTICE: Thread EPGUpdater start, auto delete: false
18:45:20 T:1763750944 NOTICE: Start - EPG thread started
