[RESOLUE] Base de donne kodi
Raspbmc (OSMC) est une distribution Raspbian intégrant XBMC (Kodi)
parrain27
Re: Base de donne kodi
Message par parrain27 » mar. 5 mai 2015 11:30
[Code11:16:35 T:1957031936 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:16:35 T:1957031936 NOTICE: -----------------------------------------------------------------------
11:16:35 T:1957031936 NOTICE: Starting Kodi (14.2 Git:Unknown). Platform: Linux ARM (Thumb) 32-bit
11:16:35 T:1957031936 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
11:16:35 T:1957031936 NOTICE: Kodi compiled Apr 9 2015 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.7 (200711)
11:16:35 T:1957031936 NOTICE: Running on Open Source Media Center 0.9.9, kernel: Linux ARM 32-bit version 3.18.10-1-osmc
11:16:35 T:1957031936 NOTICE: FFmpeg statically linked, version: 2.4.6-xbmc-2.4.6-Helix
11:16:35 T:1957031936 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
11:16:35 T:1957031936 NOTICE: ARM Features: Neon enabled
11:16:35 T:1957031936 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
11:16:35 T:1957031936 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
11:16:35 T:1957031936 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
11:16:35 T:1957031936 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
11:16:35 T:1957031936 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
11:16:35 T:1957031936 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
11:16:35 T:1957031936 NOTICE: Local hostname: osmc
11:16:35 T:1957031936 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
11:16:36 T:1957031936 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
11:16:36 T:1957031936 NOTICE: load settings...
11:16:36 T:1957031936 NOTICE: Found 1 Lists of Devices
11:16:36 T:1957031936 NOTICE: Enumerated PI devices:
11:16:36 T:1957031936 NOTICE: Device 1
11:16:36 T:1957031936 NOTICE: m_deviceName : HDMI
11:16:36 T:1957031936 NOTICE: m_displayName : HDMI
11:16:36 T:1957031936 NOTICE: m_displayNameExtra:
11:16:36 T:1957031936 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:16:36 T:1957031936 NOTICE: m_channels : FL,FR
11:16:36 T:1957031936 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
11:16:36 T:1957031936 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
11:16:36 T:1957031936 NOTICE: Device 2
11:16:36 T:1957031936 NOTICE: m_deviceName : Analogue
11:16:36 T:1957031936 NOTICE: m_displayName : Analogue
11:16:36 T:1957031936 NOTICE: m_deviceType : AE_DEVTYPE_PCM
11:16:36 T:1957031936 NOTICE: m_sampleRates : 48000
11:16:36 T:1957031936 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
11:16:36 T:1957031936 NOTICE: Device 3
11:16:36 T:1957031936 NOTICE: m_deviceName : Both
11:16:36 T:1957031936 NOTICE: m_displayName : HDMI and Analogue
11:16:36 T:1957031936 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
11:16:36 T:1957031936 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<network>
<readbufferfactor>4.0</readbufferfactor>
</network>
<imageres>540</imageres>
<fanartres>720</fanartres>
<splash>false</splash>
</advancedsettings>
11:16:36 T:1957031936 ERROR: Error loading special://profile/advancedsettings.xml, Line 3
Error reading end tag.
11:16:36 T:1957031936 NOTICE: Default DVD Player: dvdplayer
11:16:36 T:1957031936 NOTICE: Default Video Player: dvdplayer
11:16:36 T:1957031936 NOTICE: Default Audio Player: paplayer
11:16:36 T:1957031936 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:16:36 T:1957031936 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:16:36 T:1957031936 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
11:16:36 T:1957031936 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:16:36 T:1957031936 NOTICE: Loaded playercorefactory configuration
11:16:36 T:1957031936 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:16:36 T:1957031936 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:16:36 T:1956918304 NOTICE: Thread ActiveAE start, auto delete: false
11:16:36 T:1947202592 NOTICE: Thread AESink start, auto delete: false
11:16:36 T:1886385184 NOTICE: Thread CRBPWorker start, auto delete: false
11:16:36 T:1957031936 NOTICE: Running database version Addons16
11:16:37 T:1957031936 NOTICE: ADDONS: Using repository repository.xbmc.org
11:16:37 T:1957031936 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
11:16:37 T:1875252256 NOTICE: Thread CECAdapter start, auto delete: false
11:16:37 T:1846539296 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
11:16:37 T:1957031936 NOTICE: Raspberry PI firmware version: Apr 6 2015 13:30:31
Copyright (c) 2012 Broadcom
version 52e98d667b8b6ef27a2df8d817807701057bb30d (clean) (release)
11:16:37 T:1957031936 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
11:16:37 T:1957031936 NOTICE: cacheMemBufferSize: 20MB
11:16:37 T:1957031936 NOTICE: Config:
arm_control=0xa5800010
arm_freq=1000
avoid_fix_ts=1
config_hdmi_boost=2
core_freq=500
disable_commandline_tags=2
disable_l2cache=1
disable_overscan=1
emmc_pll_core=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
ignore_lcd=1
over_voltage=2
over_voltage_avs=0x1b774
pause_burst_frames=1
program_serial_random=1
sdram_freq=500
sdtv_aspect=1
temp_limit=85
device_tree=-
11:16:37 T:1957031936 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
11:16:37 T:1957031936 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
11:16:37 T:1957031936 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
11:16:37 T:1957031936 NOTICE: Found (1280x720@60.000000) at 20, setting to RES_DESKTOP at 16
11:16:37 T:1957031936 NOTICE: Checking resolution 16
11:16:37 T:1957031936 NOTICE: GL_VENDOR = Broadcom
11:16:37 T:1957031936 NOTICE: GL_RENDERER = VideoCore IV HW
11:16:37 T:1957031936 NOTICE: GL_VERSION = OpenGL ES 2.0
11:16:37 T:1957031936 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
11:16:37 T:1957031936 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
11:16:38 T:1957031936 NOTICE: Running database version Addons16
11:16:38 T:1957031936 NOTICE: Running database version ViewModes6
11:16:38 T:1957031936 NOTICE: Running database version Textures13
11:16:38 T:1957031936 NOTICE: Running database version MyMusic48
11:16:38 T:1957031936 NOTICE: Running database version MyVideos90
11:16:38 T:1957031936 NOTICE: Running database version TV26
11:16:38 T:1957031936 NOTICE: Running database version Epg8
11:16:38 T:1957031936 NOTICE: start dvd mediatype detection
11:16:38 T:1948324896 NOTICE: Thread DetectDVDMedia start, auto delete: false
11:16:40 T:1957031936 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
11:16:40 T:1957031936 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
11:16:40 T:1957031936 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
11:16:40 T:1957031936 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:16:40 T:1822389280 NOTICE: Thread LanguageInvoker start, auto delete: false
11:16:40 T:1772057632 NOTICE: Previous line repeats 5 times.
11:16:40 T:1772057632 NOTICE: Thread JobWorker start, auto delete: true
11:16:40 T:1772057632 NOTICE: PVRManager - starting up
11:16:40 T:1763406880 NOTICE: Thread PVRManager start, auto delete: false
11:16:40 T:1755018272 [/code]
désolé souci de ligne sfr orage alors je fais tout de mon tel pas pratique
mikebzh44
Message par mikebzh44 » mar. 5 mai 2015 11:36
Sur ta capture d'écran, où on voit le contenu du fichier, tu as les tags hôte. Les balises étant en anglais, il faut <host> et </host>
Et tu auras aussi un soucis avec les balises <vidéothèque> et <utilisateur>
Prends mon fichier en exemple :
<advancedsettings>
  <advancedsettings>
    <loglevel hide="true">-1</loglevel>
  </advancedsettings>
  <!-- Connexion sur ReadyNAS-RN102 -->
  <videodatabase>
    <type>mysql</type>
    <host>192.168.0.123</host>
    <port>3306</port>
    <user>xbmc</user>
    <pass>xbmc</pass>
  </videodatabase>
  <musicdatabase>
    <type>mysql</type>
    <port>3306</port>
    <user>xbmc</user>
    <pass>xbmc</pass>
  </musicdatabase>
  <videolibrary>
    <importwatchedstate>true</importwatchedstate>
    <importresumepoint>true</importresumepoint>
    <hideallitems>true</hideallitems>
  </videolibrary>
  <musiclibrary>
  </musiclibrary>
</advancedsettings>
parrain27
Message par parrain27 » mar. 5 mai 2015 12:30
Bon j'ai mis le tien complet voila sa a l'air d’être bon
12:26:09 T:1957117952  NOTICE: special://profile/ is mapped to: special://masterprofile/
12:26:09 T:1957117952  NOTICE: -----------------------------------------------------------------------
12:26:09 T:1957117952  NOTICE: Starting Kodi (14.2 Git:Unknown). Platform: Linux ARM (Thumb) 32-bit
12:26:09 T:1957117952  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
12:26:09 T:1957117952  NOTICE: Kodi compiled Apr  9 2015 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.7 (200711)
12:26:09 T:1957117952  NOTICE: Running on Open Source Media Center 0.9.9, kernel: Linux ARM 32-bit version 3.18.10-1-osmc
12:26:09 T:1957117952  NOTICE: FFmpeg statically linked, version: 2.4.6-xbmc-2.4.6-Helix
12:26:09 T:1957117952  NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
12:26:09 T:1957117952  NOTICE: ARM Features: Neon enabled
12:26:09 T:1957117952  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
12:26:09 T:1957117952  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
12:26:09 T:1957117952  NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
12:26:09 T:1957117952  NOTICE: special://home/ is mapped to: /home/osmc/.kodi
12:26:09 T:1957117952  NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
12:26:09 T:1957117952  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
12:26:09 T:1957117952  NOTICE: Local hostname: osmc
12:26:09 T:1957117952  NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
12:26:09 T:1957117952   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
12:26:09 T:1957117952  NOTICE: load settings...
12:26:10 T:1957117952  NOTICE: Found 1 Lists of Devices
12:26:10 T:1957117952  NOTICE: Enumerated PI devices:
12:26:10 T:1957117952  NOTICE:     Device 1
12:26:10 T:1957117952  NOTICE:         m_deviceName      : HDMI
12:26:10 T:1957117952  NOTICE:         m_displayName     : HDMI
12:26:10 T:1957117952  NOTICE:         m_displayNameExtra:
12:26:10 T:1957117952  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
12:26:10 T:1957117952  NOTICE:         m_channels        : FL,FR
12:26:10 T:1957117952  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
12:26:10 T:1957117952  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
12:26:10 T:1957117952  NOTICE:     Device 2
12:26:10 T:1957117952  NOTICE:         m_deviceName      : Analogue
12:26:10 T:1957117952  NOTICE:         m_displayName     : Analogue
12:26:10 T:1957117952  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
12:26:10 T:1957117952  NOTICE:         m_sampleRates     : 48000
12:26:10 T:1957117952  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
12:26:10 T:1957117952  NOTICE:     Device 3
12:26:10 T:1957117952  NOTICE:         m_deviceName      : Both
12:26:10 T:1957117952  NOTICE:         m_displayName     : HDMI and Analogue
12:26:10 T:1957117952  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
12:26:10 T:1957117952  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <advancedsettings>
                                              <network>
                                              </network>
                                            </advancedsettings>
12:26:10 T:1957117952  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
12:26:10 T:1957117952  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <!-- Base de données vidéo -->
                                              <videodatabase>
                                                <type>mysql</type>
                                                <host>192.168.0.35</host>
                                                <port>3306</port>
                                                <user>xbmc</user>
                                                <pass>xbmc</pass>
                                              </videodatabase>
                                              <!-- Base de données musique -->
                                              <musicdatabase>
                                                <type>mysql</type>
                                                <port>3306</port>
                                                <user>xbmc</user>
                                                <pass>xbmc</pass>
                                              </musicdatabase>
                                              <videolibrary>
                                                <!-- Import des status Vus / Non vus depuis les fichiers NFO -->
                                                <!-- Import des points de reprise pour les vidéos en cours -->
                                                <!-- Suppression du niveau Toutes les vidéos -->
                                              </videolibrary>
                                              <musiclibrary>
                                                <!-- Suppression du niveau Tous les albums -->
                                              </musiclibrary>
                                            </advancedsettings>
12:26:10 T:1957117952 WARNING: VIDEO database configuration is experimental.
12:26:10 T:1957117952  NOTICE: Default DVD Player: dvdplayer
12:26:10 T:1957117952  NOTICE: Default Video Player: dvdplayer
12:26:10 T:1957117952  NOTICE: Default Audio Player: paplayer
12:26:10 T:1957117952  NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:26:10 T:1957117952  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
12:26:10 T:1957117952  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
12:26:10 T:1957117952  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:26:10 T:1957117952  NOTICE: Loaded playercorefactory configuration
12:26:10 T:1957117952  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:26:10 T:1957117952  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:26:10 T:1957004320  NOTICE: Thread ActiveAE start, auto delete: false
12:26:10 T:1947202592  NOTICE: Thread AESink start, auto delete: false
12:26:10 T:1886385184  NOTICE: Thread CRBPWorker start, auto delete: false
12:26:10 T:1957117952  NOTICE: Running database version Addons16
12:26:11 T:1957117952  NOTICE: ADDONS: Using repository repository.xbmc.org
12:26:11 T:1957117952  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
12:26:11 T:1875252256  NOTICE: Thread CECAdapter start, auto delete: false
12:26:11 T:1846539296  NOTICE: Thread PeripBusUSBUdev start, auto delete: false
12:26:11 T:1957117952  NOTICE: Raspberry PI firmware version: Apr  6 2015 13:30:31
12:26:11 T:1957117952  NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
12:26:11 T:1957117952  NOTICE: cacheMemBufferSize: 20MB
12:26:11 T:1957117952  NOTICE: Config:
                                            arm_freq=1000
                                            avoid_fix_ts=1
                                            config_hdmi_boost=2
                                            core_freq=500
                                            disable_l2cache=1
                                            disable_overscan=1
                                            emmc_pll_core=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_swap=1
                                            hdmi_channel_map=8
                                            ignore_lcd=1
                                            over_voltage=2
                                            sdram_freq=500
                                            sdtv_aspect=1
                                            temp_limit=85
                                            device_tree=-
12:26:11 T:1957117952  NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
12:26:11 T:1957117952  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
12:26:11 T:1957117952  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
12:26:11 T:1957117952  NOTICE: Found (1280x720@60.000000) at 20, setting to RES_DESKTOP at 16
12:26:11 T:1957117952  NOTICE: Checking resolution 16
12:26:11 T:1957117952  NOTICE: GL_VENDOR = Broadcom
12:26:11 T:1957117952  NOTICE: GL_RENDERER = VideoCore IV HW
12:26:11 T:1957117952  NOTICE: GL_VERSION = OpenGL ES 2.0
12:26:11 T:1957117952  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
12:26:11 T:1957117952  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
12:26:12 T:1957117952  NOTICE: Running database version Addons16
12:26:12 T:1957117952  NOTICE: Running database version ViewModes6
12:26:12 T:1957117952  NOTICE: Running database version Textures13
12:26:14 T:1838150688  NOTICE: Thread CECAdapterUpdate start, auto delete: false
maintenant comment je crée ma base de donnée
parrain27
Message par parrain27 » mar. 5 mai 2015 12:40
sa charge bien le advancesetting mais sur ma tele ecran noir.....
parrain27
Message par parrain27 » mar. 5 mai 2015 12:49
bon j'ai remis le mien du depart
<advancedsettings>
  <videodatabase>
    <type>mysql</type>
    <host>***.***.***.***</host>
    <port>3306</port>
    <user>kodi</user>
    <pass>kodi</pass>
  </videodatabase>
  <musicdatabase>
    <type>mysql</type>
    <port>3306</port>
    <user>kodi</user>
    <pass>kodi</pass>
  </musicdatabase>
  <videolibrary>
  </videolibrary>
</advancedsettings>
miracle
12:33:58 T:1956442112  NOTICE: special://profile/ is mapped to: special://masterprofile/
12:33:58 T:1956442112  NOTICE: -----------------------------------------------------------------------
12:33:58 T:1956442112  NOTICE: Starting Kodi (14.2 Git:Unknown). Platform: Linux ARM (Thumb) 32-bit
12:33:58 T:1956442112  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
12:33:58 T:1956442112  NOTICE: Kodi compiled Apr  9 2015 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.7 (200711)
12:33:58 T:1956442112  NOTICE: Running on Open Source Media Center 0.9.9, kernel: Linux ARM 32-bit version 3.18.10-1-osmc
12:33:58 T:1956442112  NOTICE: FFmpeg statically linked, version: 2.4.6-xbmc-2.4.6-Helix
12:33:58 T:1956442112  NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
12:33:58 T:1956442112  NOTICE: ARM Features: Neon enabled
12:33:58 T:1956442112  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
12:33:58 T:1956442112  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
12:33:58 T:1956442112  NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
12:33:58 T:1956442112  NOTICE: special://home/ is mapped to: /home/osmc/.kodi
12:33:58 T:1956442112  NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
12:33:58 T:1956442112  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
12:33:58 T:1956442112  NOTICE: Local hostname: osmc
12:33:58 T:1956442112  NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
12:33:58 T:1956442112   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
12:33:58 T:1956442112  NOTICE: load settings...
12:33:59 T:1956442112  NOTICE: Found 1 Lists of Devices
12:33:59 T:1956442112  NOTICE: Enumerated PI devices:
12:33:59 T:1956442112  NOTICE:     Device 1
12:33:59 T:1956442112  NOTICE:         m_deviceName      : HDMI
12:33:59 T:1956442112  NOTICE:         m_displayName     : HDMI
12:33:59 T:1956442112  NOTICE:         m_displayNameExtra:
12:33:59 T:1956442112  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
12:33:59 T:1956442112  NOTICE:         m_channels        : FL,FR
12:33:59 T:1956442112  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
12:33:59 T:1956442112  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
12:33:59 T:1956442112  NOTICE:     Device 2
12:33:59 T:1956442112  NOTICE:         m_deviceName      : Analogue
12:33:59 T:1956442112  NOTICE:         m_displayName     : Analogue
12:33:59 T:1956442112  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
12:33:59 T:1956442112  NOTICE:         m_sampleRates     : 48000
12:33:59 T:1956442112  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
12:33:59 T:1956442112  NOTICE:     Device 3
12:33:59 T:1956442112  NOTICE:         m_deviceName      : Both
12:33:59 T:1956442112  NOTICE:         m_displayName     : HDMI and Analogue
12:33:59 T:1956442112  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
12:33:59 T:1956442112  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <advancedsettings>
                                              <network>
                                              </network>
                                            </advancedsettings>
12:33:59 T:1956442112  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
12:33:59 T:1956442112  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <videodatabase>
                                                <type>mysql</type>
                                                <host>192.168.1.35</host>
                                                <port>3306</port>
                                                <user>xbmc</user>
                                                <pass>xbmc</pass>
                                              </videodatabase>
                                              <musicdatabase>
                                                <type>mysql</type>
                                                <port>3306</port>
                                                <user>xbmc</user>
                                                <pass>xbmc</pass>
                                              </musicdatabase>
                                              <videolibrary>
                                              </videolibrary>
                                            </advancedsettings>
12:33:59 T:1956442112 WARNING: VIDEO database configuration is experimental.
12:33:59 T:1956442112  NOTICE: Default DVD Player: dvdplayer
12:33:59 T:1956442112  NOTICE: Default Video Player: dvdplayer
12:33:59 T:1956442112  NOTICE: Default Audio Player: paplayer
12:33:59 T:1956442112  NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:33:59 T:1956442112  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
12:33:59 T:1956442112  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
12:33:59 T:1956442112  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:33:59 T:1956442112  NOTICE: Loaded playercorefactory configuration
12:33:59 T:1956442112  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:33:59 T:1956442112  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:33:59 T:1956434976  NOTICE: Thread ActiveAE start, auto delete: false
12:33:59 T:1946154016  NOTICE: Thread AESink start, auto delete: false
12:33:59 T:1885336608  NOTICE: Thread CRBPWorker start, auto delete: false
12:33:59 T:1956442112  NOTICE: Running database version Addons16
12:34:00 T:1956442112  NOTICE: ADDONS: Using repository repository.xbmc.org
12:34:01 T:1956442112  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
12:34:01 T:1874367520  NOTICE: Thread CECAdapter start, auto delete: false
12:34:01 T:1845490720  NOTICE: Thread PeripBusUSBUdev start, auto delete: false
12:34:01 T:1956442112  NOTICE: Raspberry PI firmware version: Apr  6 2015 13:30:31
12:34:01 T:1956442112  NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
12:34:01 T:1956442112  NOTICE: cacheMemBufferSize: 20MB
12:34:01 T:1956442112  NOTICE: Config:
                                            arm_freq=1000
                                            avoid_fix_ts=1
                                            config_hdmi_boost=2
                                            core_freq=500
                                            disable_l2cache=1
                                            disable_overscan=1
                                            emmc_pll_core=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_swap=1
                                            hdmi_channel_map=8
                                            ignore_lcd=1
                                            over_voltage=2
                                            sdram_freq=500
                                            sdtv_aspect=1
                                            temp_limit=85
                                            device_tree=-
12:34:01 T:1956442112  NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
12:34:01 T:1956442112  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
12:34:01 T:1956442112  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
12:34:01 T:1956442112  NOTICE: Found (1280x720@60.000000) at 20, setting to RES_DESKTOP at 16
12:34:01 T:1956442112  NOTICE: Checking resolution 16
12:34:01 T:1956442112  NOTICE: GL_VENDOR = Broadcom
12:34:01 T:1956442112  NOTICE: GL_RENDERER = VideoCore IV HW
12:34:01 T:1956442112  NOTICE: GL_VERSION = OpenGL ES 2.0
12:34:01 T:1956442112  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
12:34:01 T:1956442112  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
12:34:01 T:1956442112  NOTICE: Running database version Addons16
12:34:01 T:1956442112  NOTICE: Running database version ViewModes6
12:34:01 T:1956442112  NOTICE: Running database version Textures13
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic48 [1049](Unknown database 'MyMusic48')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic47 [1049](Unknown database 'MyMusic47')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic46 [1049](Unknown database 'MyMusic46')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic45 [1049](Unknown database 'MyMusic45')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic44 [1049](Unknown database 'MyMusic44')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic43 [1049](Unknown database 'MyMusic43')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic42 [1049](Unknown database 'MyMusic42')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic41 [1049](Unknown database 'MyMusic41')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic40 [1049](Unknown database 'MyMusic40')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic39 [1049](Unknown database 'MyMusic39')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic38 [1049](Unknown database 'MyMusic38')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic37 [1049](Unknown database 'MyMusic37')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic36 [1049](Unknown database 'MyMusic36')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic35 [1049](Unknown database 'MyMusic35')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic34 [1049](Unknown database 'MyMusic34')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic33 [1049](Unknown database 'MyMusic33')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic32 [1049](Unknown database 'MyMusic32')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic31 [1049](Unknown database 'MyMusic31')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic30 [1049](Unknown database 'MyMusic30')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic29 [1049](Unknown database 'MyMusic29')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic28 [1049](Unknown database 'MyMusic28')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic27 [1049](Unknown database 'MyMusic27')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic26 [1049](Unknown database 'MyMusic26')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic25 [1049](Unknown database 'MyMusic25')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic24 [1049](Unknown database 'MyMusic24')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic23 [1049](Unknown database 'MyMusic23')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic22 [1049](Unknown database 'MyMusic22')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic21 [1049](Unknown database 'MyMusic21')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic20 [1049](Unknown database 'MyMusic20')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic19 [1049](Unknown database 'MyMusic19')
12:34:01 T:1956442112   ERROR: Unable to open database: MyMusic18 [1049](Unknown database 'MyMusic18')
12:34:04 T:1837102112  NOTICE: Thread CECAdapterUpdate start, auto delete: false
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos90 [1049](Unknown database 'MyVideos90')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos89 [1049](Unknown database 'MyVideos89')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos88 [1049](Unknown database 'MyVideos88')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos87 [1049](Unknown database 'MyVideos87')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos86 [1049](Unknown database 'MyVideos86')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos85 [1049](Unknown database 'MyVideos85')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos84 [1049](Unknown database 'MyVideos84')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos83 [1049](Unknown database 'MyVideos83')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos82 [1049](Unknown database 'MyVideos82')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos81 [1049](Unknown database 'MyVideos81')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos80 [1049](Unknown database 'MyVideos80')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos79 [1049](Unknown database 'MyVideos79')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos78 [1049](Unknown database 'MyVideos78')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos77 [1049](Unknown database 'MyVideos77')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos76 [1049](Unknown database 'MyVideos76')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos75 [1049](Unknown database 'MyVideos75')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos74 [1049](Unknown database 'MyVideos74')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos73 [1049](Unknown database 'MyVideos73')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos72 [1049](Unknown database 'MyVideos72')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos71 [1049](Unknown database 'MyVideos71')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos70 [1049](Unknown database 'MyVideos70')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos69 [1049](Unknown database 'MyVideos69')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos68 [1049](Unknown database 'MyVideos68')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos67 [1049](Unknown database 'MyVideos67')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos66 [1049](Unknown database 'MyVideos66')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos65 [1049](Unknown database 'MyVideos65')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos64 [1049](Unknown database 'MyVideos64')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos63 [1049](Unknown database 'MyVideos63')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos62 [1049](Unknown database 'MyVideos62')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos61 [1049](Unknown database 'MyVideos61')
12:34:18 T:1956442112   ERROR: Unable to open database: MyVideos60 [1049](Unknown database 'MyVideos60')
12:34:52 T:1956442112  NOTICE: Running database version TV26
12:34:52 T:1956442112  NOTICE: Running database version Epg8
12:34:52 T:1956442112  NOTICE: start dvd mediatype detection
12:34:52 T:1865569312  NOTICE: Thread DetectDVDMedia start, auto delete: false
Sans titre.png (12.95 Kio) Vu 8612 fois
par contre c'est pas norlmal sa ?
parrain27
Message par parrain27 » mar. 5 mai 2015 12:58
Sa viens peu être du fait j'ai pas de conection internet la
mikebzh44
Message par mikebzh44 » mar. 5 mai 2015 13:03
Oui, c'est normal. Kodi vérifie qu'il n'y aurait pas une version antérieure de ses bases pour les migrer dans la nouvelle.
Un conseil, lance le scrap depuis une autre machine que le RPi, il n'est pas très rapide pour cette tâche.
Et utilise des chemins pour les sources qui sont connues pour tous les clients Kodi, via le protocole SMB par exemple.
parrain27
Message par parrain27 » mar. 5 mai 2015 13:22
Oui j'ai virer tous les fichier video et music dans tous mes kodi mais la suis bloquée pour rescraper le temp que sfr se bouge le fion....
Je ferai un tuto complet sur le forum des je pourrais lol
mikebzh44
Re: [RESOLUE] Base de donne kodi
Message par mikebzh44 » mar. 5 mai 2015 13:31
Avant de passer sur MySQL, tu n'avais pas un Kodi avec une médiathèque chargée en locale ?
Si oui, il suffit d'enlever (ou renommer) le fichier advancedsettings.xml pour que Kodi réutilise sa base locale.
Là, tu fais un export de médiathèque en fichiers séparés. Comme ça Kodi va générer sur les disques, à côté de chaque fichier vidéo, les fichiers contenant les infos récupérées lors du scrap :
Avatar.mkv = fichier vidéo
Avatar.nfo = info sur le film (résumé, casting, ...)
Avatar-poster.jpg = jaquette du film
Avatar-fanart.jpg = poster (fond d'écran) du film
Après, tu remets le fichier advancedsettings.xml, tu redéclares tes sources et quand Kodi va faire le scan, il va utiliser en priorité ces fichiers exportés plutôt que de faire des scrap via Internet ;)
parrain27
Message par parrain27 » mar. 5 mai 2015 13:38
Non tous etait dans mes dossier film série ect dans le nas et comme j'ai tous perdu je repart de zero lol
Retourner vers « Raspbmc (OSMC) »
