isc-dhcp-serve ne marche pas
Posté : lun. 7 déc. 2015 23:53
par gat45
salut je n arrive pas a avoir le serveur dhcp fonctionnel a cause de avahi a priorie
une aide?
pi@raspberrypi:~ $ sudo service isc-dhcp-server status
* isc-dhcp-server.service - LSB: DHCP server
Loaded: loaded (/etc/init.d/isc-dhcp-server)
Active: failed (Result: exit-code) since lun. 2015-12-07 23:48:45 CET; 27s ago
Process: 1305 ExecStart=/etc/init.d/isc-dhcp-server start (code=exited, status=1/FAILURE)
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: /etc/dhcp/dhcpd.conf line 25: expec...n
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: # }
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: ^
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: Configuration file errors encounter...g
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: If you think you have received this...r
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: than a configuration issue please r...g
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: bugs on either our web page at www....e
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: before submitting a bug. These pag...r
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: process and the information we find....
d▒c. 07 23:48:45 raspberrypi isc-dhcp-server[1305]: exiting.
Hint: Some lines were ellipsized, use -l to show in full.
pi@raspberrypi:~ $ Active: failed (Result: exit-code) since lun. 2015-12-07 23:48:45 CET; 2 7s ago
-bash: erreur de syntaxe pr▒s du symbole inattendu ▒ ( ▒
pi@raspberrypi:~ $ Process: 1305 ExecStart=/etc/init.d/isc-dhcp-server start (code=exited , status=1/FAILURE)
pi@raspberrypi:~ $ sudo journalctl -xn
-- Logs begin at lun. 2015-12-07 23:28:55 CET, end at lun. 2015-12-07 23:50:09 CET. --
d▒c. 07 23:49:12 raspberrypi sudo[1337]: pam_unix(sudo:session): session closed for user ro
d▒c. 07 23:49:20 raspberrypi avahi-daemon[416]: Invalid response packet from host 192.168.0
d▒c. 07 23:49:28 raspberrypi dhcpcd[456]: eth0: Router Advertisement from fe80::226:b7ff:fe
d▒c. 07 23:49:28 raspberrypi dhcpcd[456]: eth0: fe80::226:b7ff:fe0a:33d2 router available
d▒c. 07 23:49:47 raspberrypi avahi-daemon[416]: Invalid response packet from host 192.168.0
d▒c. 07 23:50:05 raspberrypi avahi-daemon[416]: Invalid response packet from host 192.168.0
d▒c. 07 23:50:09 raspberrypi sudo[1365]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAN
d▒c. 07 23:50:09 raspberrypi sudo[1365]: pam_unix(sudo:session): session opened for user ro
lines 1-11/11 (END)
d▒c. 07 23:49:12 raspberrypi sudo[1337]: pam_unix(sudo:session): session closed for user root
d▒c. 07 23:49:20 raspberrypi avahi-daemon[416]: Invalid response packet from host 192.168.0.23.
d▒c. 07 23:49:28 raspberrypi dhcpcd[456]: eth0: Router Advertisement from fe80::226:b7ff:fe0a:33d2
d▒c. 07 23:49:47 raspberrypi avahi-daemon[416]: Invalid response packet from host 192.168.0.23.
d▒c. 07 23:50:05 raspberrypi avahi-daemon[416]: Invalid response packet from host 192.168.0.23.
d▒c. 07 23:50:09 raspberrypi sudo[1365]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl -xn
d▒c. 07 23:50:09 raspberrypi sudo[1365]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Re: isc-dhcp-serve ne marche pas
Posté : mar. 8 déc. 2015 09:21
par Korhm
les logs ne sont pas très lisibles, mais il semble y avoir une erreur de syntaxe dans ton fichier de conf et/ou le script d'exécution.
Pourrais-tu nous fournir le contenu des fichiers suivants :
Posté : mar. 8 déc. 2015 11:52
par gat45
merci de ton aide
j ai tous reinstall dans la nuit
je n ai pas trouver l erreur mais ca marche merci en tous cas !
