hotspot  [RESOLU]
marco123
hotspot
Message par marco123 » ven. 16 juin 2017 19:35
j'ai fais quelques essais sur un rpi2 , une clé wifi ...
rien a faire ...
voici mes principaux fichiers .
Pour l'instant j'en suis juste a faire un hotspot ethernet -> wifi !
Si quelqu'un pouvait voir car un œil neuf trouve un truc sur lequel je suis passé 10 fois !
merci !
/etc/hostapd/hostapd.conf
interface=wlan0
ssid=Marco
channel=1
# WPA and WPA2 configuration
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=MOT de PASSE
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
# Hardware configuration
driver=nl80211
hw_mode=g
/etc/default/hostapd
DAEMON_CONF="/etc/hostapd/hostapd.conf"
/etc/dhcp/dhcpd.conf
ddns-update-style none;
default-lease-time 86400;
max-lease-time 86400;
subnet 192.168.1.0 netmask 255.255.255.0 {
range 192.168.1.2 192.168.1.9 ;
option domain-name-servers 8.8.8.8, 8.8.4.4 ;
option domain-name "home";
option routers 192.168.1.1 ;
/etc/default/isc-dhcp-server
DHCPD_CONF="/etc/dhcp/dhcpd.conf"
INTERFACES="wlan0"
/etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.10.1
up iptables-restore < /etc/iptables.ipv4.nat
/etc/sysctl.conf
net.ipv4.ip_forward=1
# Generated by iptables-save v1.4.21 on Fri Jun 16 12:34:29 2017
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -o eth0 -j MASQUERADE
COMMIT
# Completed on Fri Jun 16 12:34:29 2017
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
-A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i wlan0 -o eth0 -j ACCEPT
COMMIT
pi@minibian:~$ sudo iwconfig
eth0 no wireless extensions.
wlan0 unassociated Nickname:"rtl_wifi"
Mode:Auto Access Point: Not-Associated Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
pi@minibian:~$ sudo ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:4a:07:d7
inet addr:192.168.1.135 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fe4a:7d7/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3405 errors:1428 dropped:741 overruns:0 frame:1428
TX packets:1783 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:311096 (303.8 KiB) TX bytes:327138 (319.4 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:104 (104.0 B) TX bytes:104 (104.0 B)
wlan0 Link encap:Ethernet HWaddr 28:10:7b:bd:e0:29
inet addr:192.168.10.1 Bcast:192.168.10.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
romaxx
Re: hotspot
Message par romaxx » ven. 16 juin 2017 21:51
il y a des distributions pour faire ce genre de taff, avec portail captif et même facturation, et qui tournent sur ARM.
Après, utiliser de l'ARM pour faire du réseau c'est pas forcement très puissant.
Il y a des alternatives toujours intéressantes comme alix board ou les wrt
Par contre tu veux faire un hotspot dans le sens ou des utilisateurs wifi se connectent sur ton AP et utilisent le réseau Ethernet ou l'inverse ? car je ne comprends pas
Adhérent à l'A.F.S.T.L
marco123
Re: hotspot  [RESOLU]
Message par marco123 » mer. 21 juin 2017 08:36
bon, trouvé !
Ma clé fait pas Access Point !
Par contre j'ai dû chercher un bon bout de temps sur la toile car la commande iw list me rend rien !
Re: hotspot
Message par domi » mer. 21 juin 2017 18:41
marco123 a écrit :bon, trouvé !
Merci de l'info Marco, car je pensais (a tord) que l'on pouvait faire du "Acces Point" avec n'importe quelle clé :cry:
marco123
Re: hotspot
Message par marco123 » mer. 21 juin 2017 19:51
Alors, tu vas rigoler! ...
C'est une dwa 131 d-link version A !
et elle existe en version plus récente en version E !
Toutes les deux ont un bouton lumineux ( mais ca tu peux pas savoir que ce voyant sert aussi de bouton ) .... En cherchant bien,
ce bouton sert a passer en mode AP ! bien, ... j'ai appuyé, appuyé, ... mais rien !
En fouillant plus loin, sur la mienne ce bouton sert au wps ( liaison auto sur un AP )
sur la version E ce bouton sert à la basculer en mode AP en utilisant un logiciel wondows ( softAP ) ! .. c'est pas pareil !
Re: hotspot
Message par dyox » lun. 10 juil. 2017 18:58
Je ne sais pas si vous avez réglé votre problème de hotspot mais il y a ce post qui en parle plutôt bien.
Modifié en dernier par dyox le mar. 11 juil. 2017 19:07, modifié 1 fois.
marco123
Re: hotspot
Message par marco123 » mar. 11 juil. 2017 18:28
oui, vu , merci !
Mais, là, a 600 km de chez moi ! ...
Je verrai en rentrant !
