Message
par daniel54 » sam. 8 août 2020 19:02
et une copie de kern.lo du 07/08
Aug 7 15:34:26 raspberrypi kernel: [3286053.070773] w1_master_driver w1_bus_master1: Attaching one wire slave 00.936f00000000 crc b1
Aug 7 15:34:26 raspberrypi kernel: [3286053.074511] w1_master_driver w1_bus_master1: Family 0 for 00.936f00000000.b1 is not registered.
Aug 7 15:35:31 raspberrypi kernel: [3286117.970613] w1_master_driver w1_bus_master1: Attaching one wire slave 00.536f00000000 crc 7b
Aug 7 15:35:31 raspberrypi kernel: [3286117.973511] w1_master_driver w1_bus_master1: Family 0 for 00.536f00000000.7b is not registered.
Aug 7 15:35:53 raspberrypi kernel: [3286140.306152] Under-voltage detected! (0x00050005)
Aug 7 15:35:54 raspberrypi kernel: [3286140.886049] usb 1-1.3: new high-speed USB device number 7 using dwc_otg
Aug 7 15:35:54 raspberrypi kernel: [3286141.097223] usb 1-1.3: New USB device found, idVendor=152d, idProduct=1561, bcdDevice= 2.04
Aug 7 15:35:54 raspberrypi kernel: [3286141.097245] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 7 15:35:54 raspberrypi kernel: [3286141.097259] usb 1-1.3: Product: SABRENT
Aug 7 15:35:54 raspberrypi kernel: [3286141.097273] usb 1-1.3: Manufacturer: SABRENT
Aug 7 15:35:54 raspberrypi kernel: [3286141.097286] usb 1-1.3: SerialNumber: DB9876543214E
Aug 7 15:35:54 raspberrypi kernel: [3286141.098787] usb 1-1.3: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
Aug 7 15:35:54 raspberrypi kernel: [3286141.098822] usb 1-1.3: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
Aug 7 15:35:54 raspberrypi kernel: [3286141.098837] usb-storage 1-1.3:1.0: USB Mass Storage device detected
Aug 7 15:35:54 raspberrypi kernel: [3286141.099425] scsi host0: usb-storage 1-1.3:1.0
Aug 7 15:35:54 raspberrypi kernel: [3286141.331279] usbcore: registered new interface driver uas
Aug 7 15:35:55 raspberrypi kernel: [3286142.146941] scsi 0:0:0:0: Direct-Access SABRENT 0204 PQ: 0 ANSI: 6
Aug 7 15:35:55 raspberrypi kernel: [3286142.175846] sd 0:0:0:0: Attached scsi generic sg0 type 0
Aug 7 15:35:56 raspberrypi kernel: [3286142.639123] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Aug 7 15:35:56 raspberrypi kernel: [3286142.639562] sd 0:0:0:0: [sda] Write Protect is off
Aug 7 15:35:56 raspberrypi kernel: [3286142.639581] sd
0:0:0:0: [sda] Mode Sense: 47 00 00 08
Aug 7 15:35:56 raspberrypi kernel: [3286142.644819] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 7 15:35:56 raspberrypi kernel: [3286142.680380] sda: sda1 sda2
Aug 7 15:35:56 raspberrypi kernel: [3286142.686954] sd 0:0:0:0: [sda] Attached SCSI disk
Aug 7 15:35:57 raspberrypi kernel: [3286143.611229] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Aug 7 15:35:57 raspberrypi kernel: [3286143.672776] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Aug 7 15:36:08 raspberrypi kernel: [3286154.866118] Voltage normalised (0x00000000)
Aug 7 15:36:33 raspberrypi kernel: [3286180.280593] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d36f00000000 crc f7
Aug 7 15:36:33 raspberrypi kernel: [3286180.284703] w1_master_driver w1_bus_master1: Family 0 for 00.d36f00000000.f7 is not registered.
Aug 7 15:36:59 raspberrypi kernel: [3286206.310550] w1_master_driver w1_bus_master1: Attaching one wire slave 00.336f00000000 crc 1e
Aug 7 15:36:59 raspberrypi kernel: [3286206.314215] w1_master_driver w1_bus_master1: Family 0 for 00.336f00000000.1e is not registered.
Aug 7 15:37:27 raspberrypi kernel: [3286233.906064] Under-voltage detected! (0x000d0005)
Aug 7 15:37:31 raspberrypi kernel: [3286238.065998] Voltage normalised (0x00000000)
Aug 7 15:37:39 raspberrypi kernel: [3286245.520507] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b36f00000000 crc 92
Aug 7 15:37:39 raspberrypi kernel: [3286245.525540] w1_master_driver w1_bus_master1: Family 0 for 00.b36f00000000.92 is not registered.
Aug 7 15:37:44 raspberrypi kernel: [3286250.546095] Under-voltage detected! (0x000d0005)
Aug 7 15:37:48 raspberrypi kernel: [3286254.706008] Voltage normalised (0x00000000)
Aug 7 15:38:18 raspberrypi kernel: [3286284.710631] w1_master_driver w1_bus_master1: Attaching one wire slave 00.736f00000000 crc 58
Aug 7 15:38:18 raspberrypi kernel: [3286284.714297] w1_master_driver w1_bus_master1: Family 0 for 00.736f00000000.58 is not registered.
Aug 7 15:39:20 raspberrypi kernel: [3286347.040249] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f36f00000000 crc d4
Aug 7 15:39:20 raspberrypi kernel: [3286347.044540] w1_master_driver w1_bus_master1: Family 0 for 00.f36f00000000.d4 is not registered.
Aug 7 15:40:13 raspberrypi kernel: [3286399.470464] w1_master_driver w1_bus_master1: Attaching one wire slave 00.0b6f00000000 crc 62
Aug 7 15:40:13 raspberrypi kernel: [3286399.474462] w1_master_driver w1_bus_master1: Family 0 for 00.0b6f00000000.62 is not registered.
Aug 7 15:41:16 raspberrypi kernel: [3286463.100252] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8b6f00000000 crc ee
Aug 7 15:41:16 raspberrypi kernel: [3286463.104313] w1_master_driver w1_bus_master1: Family 0 for 00.8b6f00000000.ee is not registered.
Aug 7 15:41:45 raspberrypi kernel: [3286491.826630] rpi_firmware_get_throttled: 2 callbacks suppressed
Aug 7 15:41:45 raspberrypi kernel: [3286491.826642] Under-voltage detected! (0x000d0005)
Aug 7 15:41:49 raspberrypi kernel: [3286495.985638] rpi_firmware_get_throttled: 2 callbacks suppressed
Aug 7 15:41:49 raspberrypi kernel: [3286495.985647] Voltage normalised (0x00000000)
Aug 7 15:41:54 raspberrypi kernel: [3286500.830698] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4b6f00000000 crc 24
Aug 7 15:41:54 raspberrypi kernel: [3286500.834502] w1_master_driver w1_bus_master1: Family 0 for 00.4b6f00000000.24 is not registered.
Aug 7 15:42:02 raspberrypi kernel: [3286508.465790] Under-voltage detected! (0x000d0005)
Aug 7 15:42:08 raspberrypi kernel: [3286514.705601] Voltage normalised (0x00000000)
Aug 7 15:42:45 raspberrypi kernel: [3286551.632347] w1_master_driver w1_bus_master1: Attaching one wire slave 00.cb6f00000000 crc a8
Aug 7 15:42:45 raspberrypi kernel: [3286551.640284] w1_master_driver w1_bus_master1: Family 0 for 00.cb6f00000000.a8 is not registered.
Aug 7 15:42:45 raspberrypi kernel: [3286552.145645] Under-voltage detected! (0x000d0005)
Aug 7 15:42:49 raspberrypi kernel: [3286556.305558] Voltage normalised (0x00080000)
Aug 7 15:43:51 raspberrypi kernel: [3286617.600691] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2b6f00000000 crc 41
Aug 7 15:43:51 raspberrypi kernel: [3286617.604611] w1_master_driver w1_bus_master1: Family 0 for 00.2b6f00000000.41 is not registered.
Aug 7 15:44:54 raspberrypi kernel: [3286681.230445] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ab6f00000000 crc cd
Aug 7 15:44:55 raspberrypi kernel: [3286681.390004] w1_master_driver w1_bus_master1: Family 0 for 00.ab6f00000000.cd is not registered.
Aug 7 15:45:58 raspberrypi kernel: [3286745.340637] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6b6f00000000 crc 07
Aug 7 15:45:59 raspberrypi kernel: [3286745.385025] w1_master_driver w1_bus_master1: Family 0 for 00.6b6f00000000.07 is not registered.
Aug 7 15:46:49 raspberrypi kernel: [3286796.039823] w1_master_driver w1_bus_master1: Attaching one wire slave 00.eb6f00000000 crc 8b
Aug 7 15:46:49 raspberrypi kernel: [3286796.241847] w1_master_driver w1_bus_master1: Family 0 for 00.eb6f00000000.8b is not registered.
Aug 7 15:46:53 raspberrypi kernel: [3286799.666158] rpi_firmware_get_throttled: 6 callbacks suppressed
Aug 7 15:46:53 raspberrypi kernel: [3286799.666170] Under-voltage detected! (0x000d0005)
Aug 7 15:47:12 raspberrypi kernel: [3286818.385270] rpi_firmware_get_throttled: 6 callbacks suppressed
Aug 7 15:47:12 raspberrypi kernel: [3286818.385279] Voltage normalised (0x00000000)
Aug 7 15:47:30 raspberrypi kernel: [3286837.105269] Under-voltage detected! (0x000d0005)
Aug 7 15:47:34 raspberrypi kernel: [3286841.265218] Voltage normalised (0x00080000)
Aug 7 15:47:36 raspberrypi kernel: [3286843.345298] Under-voltage detected! (0x000d0005)
Aug 7 15:47:41 raspberrypi kernel: [3286847.505207] Voltage normalised (0x00000000)
AAug 7 15:55:22 raspberrypi kernel: [3287308.393552] w1_master_driver w1_bus_master1: Family 0 for 00.876f00000000.4d is not registered.
Aug 7 15:56:00 raspberrypi kernel: [3287346.704819] rpi_firmware_get_throttled: 8 callbacks suppressed
Aug 7 15:56:00 raspberrypi kernel: [3287346.704831] Under-voltage detected! (0x000d0005)
Aug 7 15:56:10 raspberrypi kernel: [3287357.104632] rpi_firmware_get_throttled: 8 callbacks suppressed
Aug 7 15:56:10 raspberrypi kernel: [3287357.104643] Voltage normalised (0x00080000)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577518] php invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
Aug 7 16:00:11 raspberrypi kernel: [3287597.577541] CPU: 2 PID: 20214 Comm: php Tainted: G C 5.4.47-v7+ #1322
Aug 7 16:00:11 raspberrypi kernel: [3287597.577545] Hardware name: BCM2835
Aug 7 16:00:11 raspberrypi kernel: [3287597.577550] Backtrace:
Aug 7 16:00:11 raspberrypi kernel: [3287597.577577] [<8010d458>] (dump_backtrace) from [<8010d750>] (show_stack+0x20/0x24)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577587] r6:a33f6000 r5:00000000 r4:80d93c74 r3:b2b67ae7
Aug 7 16:00:11 raspberrypi kernel: [3287597.577601] [<8010d730>] (show_stack) from [<808b08c4>] (dump_stack+0xe0/0x124)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577615] [<808b07e4>] (dump_stack) from [<8027a1d8>] (dump_header+0x64/0x290)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577628] r8:80d08140 r7:821f8840 r6:0000029e r5:942b0000 r4:a33f7e48 r3:b2b67ae7
Aug 7 16:00:11 raspberrypi kernel: [3287597.577640] [<8027a174>] (dump_header) from [<8027a4ec>] (oom_kill_process+0xe8/0x390)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577652] r10:00000c7f r9:af17cc40 r8:80d08140 r7:a33f7e48 r6:942b0000 r5:942b0550
Aug 7 16:00:11 raspberrypi kernel: [3287597.577657] r4:80aaf4cc
Aug 7 16:00:11 raspberrypi kernel: [3287597.577670] [<8027a404>] (oom_kill_process) from [<8027b14c>] (out_of_memory+0xfc/0x400)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577682] r10:00000c7f r9:af17cc40 r8:80d08140 r7:80d08140 r6:80d04f48 r5:a33f7e48
Aug 7 16:00:11 raspberrypi kernel: [3287597.577687] r4:80d08448
Aug 7 16:00:11 raspberrypi kernel: [3287597.577702] [<8027b050>] (out_of_memory) from [<802c1684>] (__alloc_pages_nodemask+0x10a0/0x11fc)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577713] r10:00000000 r9:80d95948 r8:80d05684 r7:00000406 r6:000002c0 r5:00000000
Aug 7 16:00:11 raspberrypi kernel: [3287597.577718] r4:00000000
Aug 7 16:00:11 raspberrypi kernel: [3287597.577732] [<802c05e4>] (__alloc_pages_nodemask) from [<802aaf28>] (handle_mm_fault+0x434/0xa4c)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577744] r10:00000800 r9:87448a40 r8:00000817 r7:87448a00 r6:b2040540 r5:80d04f48
Aug 7 16:00:11 raspberrypi kernel: [3287597.577749] r4:74862000
Aug 7 16:00:11 raspberrypi kernel: [3287597.577762] [<802aaaf4>] (handle_mm_fault) from [<808d1dec>] (do_page_fault+0x320/0x3a8)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577774] r10:00000800 r9:87448a40 r8:00000817 r7:87448a00 r6:748620a0 r5:abc88f40
Aug 7 16:00:11 raspberrypi kernel: [3287597.577779] r4:a33f7fb0
Aug 7 16:00:11 raspberrypi kernel: [3287597.577792] [<808d1acc>] (do_page_fault) from [<80115854>] (do_DataAbort+0x48/0xc4)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577804] r10:00310eec r9:0030efa0 r8:a33f7fb0 r7:748620a0 r6:808d1acc r5:00000817
Aug 7 16:00:11 raspberrypi kernel: [3287597.577809] r4:80d0a7d4
Aug 7 16:00:11 raspberrypi kernel: [3287597.577821] [<8011580c>] (do_DataAbort) from [<80101d24>] (__dabt_usr+0x44/0x60)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577827] Exception stack(0xa33f7fb0 to 0xa33f7ff8)
Aug 7 16:00:11 raspberrypi kernel: [3287597.577836] 7fa0: 74862000 000000a0 74862140 748620a0
Aug 7 16:00:11 raspberrypi kernel: [3287597.577848] 7fc0: 00000001 74800040 0000000c 002b30c4 769cf640 0030efa0 00310eec 00271438
Aug 7 16:00:11 raspberrypi kernel: [3287597.577857] 7fe0: 74862f00 7e8515e8 00000f00 0019c080 20000010 ffffffff
Aug 7 16:00:11 raspberrypi kernel: [3287597.577868] r8:10c5387d r7:10c5383d r6:ffffffff r5:20000010 r4:0019c080
Aug 7 16:00:11 raspberrypi kernel: [3287597.577873] Mem-Info:
Aug 7 16:00:11 raspberrypi kernel: [3287597.577897] active_anon:90938 inactive_anon:107579 isolated_anon:0
Aug 7 16:00:11 raspberrypi kernel: [3287597.577897] active_file:1606 inactive_file:1637 isolated_file:115
Aug 7 16:00:11 raspberrypi kernel: [3287597.577897] unevictable:3 dirty:16 writeback:0 unstable:0
Aug 7 16:00:11 raspberrypi kernel: [3287597.577897] slab_reclaimable:3296 slab_unreclaimable:5301
Aug 7 16:00:11 raspberrypi kernel: [3287597.577897] mapped:31839 shmem:43160 pagetables:2543 bounce:0
Aug 7 16:00:11 raspberrypi kernel: [3287597.577897] free:7166 free_pcp:431 free_cma:378
Aug 7 16:00:11 raspberrypi kernel: [3287597.577916] Node 0 active_anon:363752kB inactive_anon:430316kB active_file:6424kB inactive_file:6548kB unevictable:12kB isolated(anon):0kB isolated(file):332kB mapped:127356kB dirty:64kB writeback:0kB shmem:172640kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
Aug 7 16:00:11 raspberrypi kernel: [3287597.577941] Normal free:28664kB min:53248kB low:57344kB high:61440kB active_anon:363752kB inactive_anon:430316kB active_file:7356kB inactive_file:6944kB unevictable:12kB writepending:64kB present:917504kB managed:896196kB mlocked:12kB kernel_stack:2768kB pagetables:10172kB bounce:0kB free_pcp:1876kB local_pcp:152kB free_cma:1512kB
Aug 7 16:00:11 raspberrypi kernel: [3287597.577948] lowmem_reserve[]: 0 0
Aug 7 16:00:11 raspberrypi kernel: [3287597.577964] Normal: 2091*4kB (UMEC) 1049*8kB (UMEC) 338*16kB (UMEC) 129*32kB (UMEC) 52*64kB (UEC) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 29620kB
Aug 7 16:00:11 raspberrypi kernel: [3287597.578032] 47846 total pagecache pages
Aug 7 16:00:11 raspberrypi kernel: [3287597.578044] 1337 pages in swap cache
Aug 7 16:00:11 raspberrypi kernel: [3287597.578054] Swap cache stats: add 42420, delete 41083, find 3093114/3094707
Aug 7 16:00:11 raspberrypi kernel: [3287597.578061] Free swap = 0kB
Aug 7 16:00:11 raspberrypi kernel: [3287597.578069] Total swap = 102396kB
Aug 7 16:00:11 raspberrypi kernel: [3287597.578077] 229376 pages RAM
Aug 7 16:00:11 raspberrypi kernel: [3287597.578085] 0 pages HighMem/MovableOnly
Aug 7 16:00:11 raspberrypi kernel: [3287597.578092] 5327 pages reserved
Aug 7 16:00:11 raspberrypi kernel: [3287597.578100] 16384 pages cma reserved
Aug 7 16:00:11 raspberrypi kernel: [3287597.578108] Tasks state (memory values in pages):
Aug 7 16:00:11 raspberrypi kernel: [3287597.578117] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
Aug 7 16:00:11 raspberrypi kernel: [3287597.578148] [ 109] 0 109 7211 394 22528 50 0 systemd-journal
Aug 7 16:00:11 raspberrypi kernel: [3287597.578162] [ 139] 0 139 3697 90 18432 157 -1000 systemd-udevd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578180] [ 333] 105 333 1650 117 14336 47 -900 dbus-daemon
Aug 7 16:00:11 raspberrypi kernel: [3287597.578194] [ 352] 0 352 5939 198 16384 104 0 rsyslogd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578209] [ 353] 0 353 2500 12 18432 84 0 wpa_supplicant
Aug 7 16:00:11 raspberrypi kernel: [3287597.578223] [ 354] 0 354 1855 57 14336 68 0 systemd-logind
Aug 7 16:00:11 raspberrypi kernel: [3287597.578237] [ 357] 0 357 1330 61 14336 26 0 cron
Aug 7 16:00:11 raspberrypi kernel: [3287597.578251] [ 360] 65534 360 1324 6 12288 55 0 thd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578265] [ 364] 108 364 1632 77 16384 45 0 avahi-daemon
Aug 7 16:00:11 raspberrypi kernel: [3287597.578280] [ 367] 0 367 7156 47 16384 11 0 rngd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578294] [ 383] 108 383 1599 7 14336 68 0 avahi-daemon
Aug 7 16:00:11 raspberrypi kernel: [3287597.578309] [ 384] 0 384 734 63 12288 37 0 dhcpcd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578329] [ 471] 0 471 9356 70 28672 96 0 lightdm
Aug 7 16:00:11 raspberrypi kernel: [3287597.578353] [ 486] 0 486 990 0 12288 31 0 agetty
Aug 7 16:00:11 raspberrypi kernel: [3287597.578368] [ 488] 0 488 1469 3 14336 112 0 login
Aug 7 16:00:11 raspberrypi kernel: [3287597.578382] [ 499] 110 499 1978 62 16384 51 0 ntpd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578397] [ 519] 0 519 2552 0 18432 134 -1000 sshd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578411] [ 537] 0 537 2643 52 18432 91 0 wpa_supplicant
Aug 7 16:00:11 raspberrypi kernel: [3287597.578426] [ 547] 0 547 57841 8986 155648 2762 0 Xorg
Aug 7 16:00:11 raspberrypi kernel: [3287597.578440] [ 640] 111 640 178741 42557 417792 8056 0 mysqld
Aug 7 16:00:11 raspberrypi kernel: [3287597.578454] [ 641] 0 641 35153 737 69632 801 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.578468] [ 666] 0 666 11809 816 36864 850 0 fail2ban-server
Aug 7 16:00:11 raspberrypi kernel: [3287597.578483] [ 720] 0 720 7409 22 24576 149 0 lightdm
Aug 7 16:00:11 raspberrypi kernel: [3287597.578497] [ 733] 1000 733 2439 94 20480 105 0 systemd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578512] [ 737] 1000 737 2844 59 18432 272 0 (sd-pam)
Aug 7 16:00:11 raspberrypi kernel: [3287597.578526] [ 750] 1000 750 1578 2 10240 352 0 bash
Aug 7 16:00:11 raspberrypi kernel: [3287597.578540] [ 751] 1000 751 12807 97 40960 222 0 lxsession
Aug 7 16:00:11 raspberrypi kernel: [3287597.578554] [ 764] 1000 764 1628 65 16384 52 0 dbus-daemon
Aug 7 16:00:11 raspberrypi kernel: [3287597.578569] [ 819] 1000 819 948 10 10240 42 0 ssh-agent
Aug 7 16:00:11 raspberrypi kernel: [3287597.578583] [ 826] 1000 826 9918 63 24576 81 0 gvfsd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578597] [ 834] 1000 834 13567 0 32768 154 0 gvfsd-fuse
Aug 7 16:00:11 raspberrypi kernel: [3287597.578612] [ 850] 1000 850 13585 552 40960 233 0 openbox
Aug 7 16:00:11 raspberrypi kernel: [3287597.578626] [ 854] 1000 854 10887 73 40960 193 0 lxpolkit
Aug 7 16:00:11 raspberrypi kernel: [3287597.578640] [ 857] 1000 857 74263 40481 245760 1900 0 lxpanel
Aug 7 16:00:11 raspberrypi kernel: [3287597.578655] [ 859] 1000 859 36279 1404 69632 117 0 pcmanfm
Aug 7 16:00:11 raspberrypi kernel: [3287597.578669] [ 865] 1000 865 948 0 12288 51 0 ssh-agent
Aug 7 16:00:11 raspberrypi kernel: [3287597.578684] [ 872] 0 872 9733 111 30720 336 0 polkitd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578698] [ 888] 1000 888 6518 2 20480 113 0 menu-cached
Aug 7 16:00:11 raspberrypi kernel: [3287597.578714] [ 901] 1000 901 23293 249 49152 121 0 gvfs-udisks2-vo
Aug 7 16:00:11 raspberrypi kernel: [3287597.578728] [ 904] 0 904 16760 312 40960 177 0 udisksd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578743] [ 933] 1000 933 9324 51 26624 85 0 gvfs-mtp-volume
Aug 7 16:00:11 raspberrypi kernel: [3287597.578758] [ 951] 1000 951 12751 0 30720 187 0 gvfs-afc-volume
Aug 7 16:00:11 raspberrypi kernel: [3287597.578773] [ 969] 1000 969 9344 0 30720 117 0 gvfs-goa-volume
Aug 7 16:00:11 raspberrypi kernel: [3287597.578787] [ 973] 1000 973 9715 58 28672 105 0 gvfs-gphoto2-vo
Aug 7 16:00:11 raspberrypi kernel: [3287597.578802] [ 986] 1000 986 12321 100 30720 93 0 gvfsd-trash
Aug 7 16:00:11 raspberrypi kernel: [3287597.578817] [ 1259] 0 1259 1822 3 14336 85 0 sudo
Aug 7 16:00:11 raspberrypi kernel: [3287597.578830] [ 1263] 0 1263 30920 2 135168 1127 0 nodejs
Aug 7 16:00:11 raspberrypi kernel: [3287597.578845] [ 1295] 33 1295 39840 5850 90112 952 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.578859] [ 1419] 33 1419 34138 3985 81920 1698 0 python
Aug 7 16:00:11 raspberrypi kernel: [3287597.578873] [ 16930] 0 16930 11725 230 36864 108 0 packagekitd
Aug 7 16:00:11 raspberrypi kernel: [3287597.578888] [ 16690] 33 16690 35309 2463 69632 669 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.578903] [ 13654] 33 13654 35315 2592 69632 666 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.578917] [ 23071] 33 23071 35321 2594 69632 667 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.578931] [ 23079] 33 23079 35310 2316 69632 672 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.578945] [ 23086] 33 23086 35314 2298 69632 673 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.578960] [ 7257] 33 7257 4374 1767 26624 0 0 python
Aug 7 16:00:11 raspberrypi kernel: [3287597.578974] [ 32200] 33 32200 35323 2347 69632 674 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.578988] [ 18908] 33 18908 35306 2507 69632 670 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.579002] [ 18909] 33 18909 35314 2309 69632 673 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.579016] [ 21273] 33 21273 35301 2298 69632 673 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.579031] [ 21535] 33 21535 35311 1621 69632 676 0 apache2
Aug 7 16:00:11 raspberrypi kernel: [3287597.579050] [ 15785] 1000 15785 127125 17042 348160 0 0 chromium-browse
Aug 7 16:00:11 raspberrypi kernel: [3287597.579065] [ 15812] 1000 15812 46882 1363 143360 0 0 chromium-browse
Aug 7 16:00:11 raspberrypi kernel: [3287597.579080] [ 15816] 1000 15816 46882 1418 92160 0 0 chromium-browse
Aug 7 16:00:11 raspberrypi kernel: [3287597.579095] [ 15845] 1000 15845 74987 3305 208896 0 200 chromium-browse
Aug 7 16:00:11 raspberrypi kernel: [3287597.579109] [ 16002] 1000 16002 89935 10871 339968 0 300 chromium-browse
Aug 7 16:00:11 raspberrypi kernel: [3287597.579123] [ 16424] 1000 16424 101963 13237 372736 0 300 chromium-browse
Aug 7 16:00:11 raspberrypi kernel: [3287597.579139] [ 18892] 1000 18892 11369 1075 40960 0 0 leafpad
Aug 7 16:00:11 raspberrypi kernel: [3287597.579155] [ 20162] 33 20162 34666 3030 67584 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579171] [ 20176] 33 20176 34666 3026 65536 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579186] [ 20189] 33 20189 34666 2998 69632 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579201] [ 20201] 33 20201 34666 3056 67584 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579216] [ 20214] 33 20214 34666 3033 67584 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579230] [ 20226] 33 20226 34666 3011 67584 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579249] [ 20238] 33 20238 34666 3003 69632 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579270] [ 20251] 33 20251 34666 3027 67584 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579285] [ 20263] 33 20263 34666 2982 67584 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579299] [ 20276] 33 20276 34666 3164 69632 0 0 php
Aug 7 16:00:11 raspberrypi kernel: [3287597.579310] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,task=chromium-browse,pid=16424,uid=1000
Aug 7 16:00:11 raspberrypi kernel: [3287597.579425] Out of memory: Killed process 16424 (chromium-browse) total-vm:407852kB, anon-rss:42860kB, file-rss:0kB, shmem-rss:10088kB, UID:1000 pgtables:364kB oom_score_adj:300
Aug 7 16:00:11 raspberrypi kernel: [3287597.598952] oom_reaper: reaped process 16424 (chromium-browse), now anon-rss:0kB, file-rss:0kB, shmem-rss:9964kB
Aug 7 16:00:16 raspberrypi kernel: [3287602.544595] Under-voltage detected! (0x000d0005)
Aug 7 16:00:20 raspberrypi kernel: [3287606.704329] Voltage normalised (0x00080000)
Aug 7 16:00:39 raspberrypi kernel: [3287625.434403] Under-voltage detected! (0x000d0005)
Aug 7 16:00:51 raspberrypi kernel: [3287637.904279] Voltage normalised (0x00080000)
Aug 7 16:01:07 raspberrypi kernel: [3287653.468861] w1_master_driver w1_bus_master1: Attaching one wire slave 00.176f00000000 crc 5c
Aug 7 16:01:07 raspberrypi kernel: [3287653.472907] w1_master_driver w1_bus_master1: Family 0 for 00.176f00000000.5c is not registered.
Aug 7 16:01:46 raspberrypi kernel: [3287692.668781] w1_master_driver w1_bus_master1: Attaching one wire slave 00.976f00000000 crc d0
Aug 7 16:01:46 raspberrypi kernel: [3287692.672700] w1_master_driver w1_bus_master1: Family 0 for 00.976f00000000.d0 is not registered.
Aug 7 16:02:51 raspberrypi kernel: [3287757.388699] w1_master_driver w1_bus_master1: Attaching one wire slave 00.576f00000000 crc 1a
Aug 7 16:02:51 raspberrypi kernel: [3287757.392622] w1_master_driver w1_bus_master1: Family 0 for 00.576f00000000.1a is not registered.
Aug 7 16:03:53 raspberrypi kernel: [3287819.708615] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d76f00000000 crc 96
Aug 7 16:03:53 raspberrypi kernel: [3287819.712457] w1_master_driver w1_bus_master1: Family 0 for 00.d76f00000000.96 is not registered.
Aug 7 16:05:11 raspberrypi kernel: [3287897.608536] w1_master_driver w1_bus_master1: Attaching one wire slave 00.376f00000000 crc 7f
Aug 7 16:05:11 raspberrypi kernel: [3287897.612494] w1_master_driver w1_bus_master1: Family 0 for 00.376f00000000.7f is not registered.
Aug 7 16:05:50 raspberrypi kernel: [3287936.788586] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b76f00000000 crc f3
Aug 7 16:05:50 raspberrypi kernel: [3287936.792685] w1_master_driver w1_bus_master1: Family 0 for 00.b76f00000000.f3 is not registered.
Aug 7 16:06:39 raspberrypi kernel: [3287986.118484] w1_master_driver w1_bus_master1: Attaching one wire slave 00.776f00000000 crc 39
Aug 7 16:06:39 raspberrypi kernel: [3287986.122373] w1_master_driver w1_bus_master1: Family 0 for 00.776f00000000.39 is not registered.
Aug 7 16:07:31 raspberrypi kernel: [3288038.158485] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f76f00000000 crc b5
Aug 7 16:07:31 raspberrypi kernel: [3288038.162387] w1_master_driver w1_bus_master1: Family 0 for 00.f76f00000000.b5 is not registered.
Aug 7 16:08:23 raspberrypi kernel: [3288090.278528] w1_master_driver w1_bus_master1: Attaching one wire slave 00.0f6f00000000 crc 03
Aug 7 16:08:23 raspberrypi kernel: [3288090.282334] w1_master_driver w1_bus_master1: Family 0 for 00.0f6f00000000.03 is not registered.
Aug 7 16:09:27 raspberrypi kernel: [3288153.878277] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8f6f00000000 crc 8f
Aug 7 16:09:27 raspberrypi kernel: [3288153.882078] w1_master_driver w1_bus_master1: Family 0 for 00.8f6f00000000.8f is not registered.
Aug 7 16:10:04 raspberrypi kernel: [3288191.183681] Under-voltage detected! (0x000d0005)
Aug 7 16:10:05 raspberrypi kernel: [3288191.788684] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4f6f00000000 crc 45
Aug 7 16:10:05 raspberrypi kernel: [3288191.795855] w1_master_driver w1_bus_master1: Family 0 for 00.4f6f00000000.45 is not registered.
Aug 7 16:10:08 raspberrypi kernel: [3288195.343640] Voltage normalised (0x00080008)
Aug 7 16:10:56 raspberrypi kernel: [3288242.548216] w1_master_driver w1_bus_master1: Attaching one wire slave 00.cf6f00000000 crc c9
Aug 7 16:10:56 raspberrypi kernel: [3288242.552393] w1_master_driver w1_bus_master1: Family 0 for 00.cf6f00000000.c9 is not registered.
Aug 7 16:11:21 raspberrypi kernel: [3288267.628505] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2f6f00000000 crc 20
Aug 7 16:11:21 raspberrypi kernel: [3288267.632362] w1_master_driver w1_bus_master1: Family 0 for 00.2f6f00000000.20 is not registered.
Aug 7 16:12:14 raspberrypi kernel: [3288320.948237] w1_master_driver w1_bus_master1: Attaching one wire slave 00.af6f00000000 crc ac
Aug 7 16:12:14 raspberrypi kernel: [3288320.952212] w1_master_driver w1_bus_master1: Family 0 for 00.af6f00000000.ac is not registered.
Aug 7 16:13:03 raspberrypi kernel: [3288370.063541] Under-voltage detected! (0x000d0005)
Aug 7 16:13:07 raspberrypi kernel: [3288374.223442] Voltage normalised (0x00080000)
Aug 7 16:13:18 raspberrypi kernel: [3288384.547888] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6f6f00000000 crc 66
Aug 7 16:13:18 raspberrypi kernel: [3288384.551064] w1_master_driver w1_bus_master1: Family 0 for 00.6f6f00000000.66 is not registered.
Aug 7 16:13:20 raspberrypi kernel: [3288386.703451] Under-voltage detected! (0x000d0005)
Aug 7 16:13:26 raspberrypi kernel: [3288392.944274] Voltage normalised (0x00000000)
Aug 7 16:14:08 raspberrypi kernel: [3288435.308011] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ef6f00000000 crc ea
Aug 7 16:14:08 raspberrypi kernel: [3288435.311877] w1_master_driver w1_bus_master1: Family 0 for 00.ef6f00000000.ea is not registered.
Aug 7 16:15:11 raspberrypi kernel: [3288498.307879] w1_master_driver w1_bus_master1: Attaching one wire slave 00.1f6f00000000 crc 9e
Aug 7 16:15:11 raspberrypi kernel: [3288498.311766] w1_master_driver w1_bus_master1: Family 0 for 00.1f6f00000000.9e is not registered.
Aug 7 16:15:51 raspberrypi kernel: [3288537.427762] w1_master_driver w1_bus_master1: Attaching one wire slave 00.9f6f00000000 crc 12
Aug 7 16:15:51 raspberrypi kernel: [3288537.431532] w1_master_driver w1_bus_master1: Family 0 for 00.9f6f00000000.12 is not registered.
Aug 7 16:16:25 raspberrypi kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Linux version 5.4.47-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1322 SMP Wed Jun 17 17:52:39 BST 2020
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] CPU: div instructions available: patching division code
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Memory policy: Data cache writealloc
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Reserved memory: created CMA memory pool at 0x34000000, size 64 MiB
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] On node 0 totalpages: 229376
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Normal zone: 1792 pages used for memmap
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Normal zone: 0 pages reserved
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Normal zone: 229376 pages, LIFO batch:63
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] percpu: Embedded 20 pages/cpu s49792 r8192 d23936 u81920
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] pcpu-alloc: s49792 r8192 d23936 u81920 alloc=20*4096
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 227584
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] Memory: 829636K/917504K available (8192K kernel code, 680K rwdata, 2532K rodata, 1024K init, 824K bss, 22332K reserved, 65536K cma-reserved)
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] ftrace: allocating 27907 entries in 55 pages
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x328/0x4e8 with crng_init=0
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Aug 7 16:16:26 raspberrypi kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Aug 7 16:16:26 raspberrypi kernel: [ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Aug 7 16:16:26 raspberrypi kernel: [ 0.000021] Switching to timer-based delay loop, resolution 52ns
Aug 7 16:16:26 raspberrypi kernel: [ 0.000282] Console: colour dummy device 80x30
Aug 7 16:16:26 raspberrypi kernel: [ 0.000868] printk: console [tty1] enabled
Aug 7 16:16:26 raspberrypi kernel: [ 0.000935] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Aug 7 16:16:26 raspberrypi kernel: [ 0.000984] pid_max: default: 32768 minimum: 301
Aug 7 16:16:26 raspberrypi kernel: [ 0.001324] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 0.001370] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 0.002530] CPU: Testing write buffer coherency: ok
Aug 7 16:16:26 raspberrypi kernel: [ 0.003085] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Aug 7 16:16:26 raspberrypi kernel: [ 0.004030] Setting up static identity map for 0x100000 - 0x10003c
Aug 7 16:16:26 raspberrypi kernel: [ 0.004249] rcu: Hierarchical SRCU implementation.
Aug 7 16:16:26 raspberrypi kernel: [ 0.004937] smp: Bringing up secondary CPUs ...
Aug 7 16:16:26 raspberrypi kernel: [ 0.006044] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Aug 7 16:16:26 raspberrypi kernel: [ 0.007270] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Aug 7 16:16:26 raspberrypi kernel: [ 0.008398] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Aug 7 16:16:26 raspberrypi kernel: [ 0.008551] smp: Brought up 1 node, 4 CPUs
Aug 7 16:16:26 raspberrypi kernel: [ 0.008637] SMP: Total of 4 processors activated (153.60 BogoMIPS).
Aug 7 16:16:26 raspberrypi kernel: [ 0.008665] CPU: All CPU(s) started in HYP mode.
Aug 7 16:16:26 raspberrypi kernel: [ 0.008690] CPU: Virtualization extensions available.
Aug 7 16:16:26 raspberrypi kernel: [ 0.009606] devtmpfs: initialized
Aug 7 16:16:26 raspberrypi kernel: [ 0.025906] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Aug 7 16:16:26 raspberrypi kernel: [ 0.026200] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Aug 7 16:16:26 raspberrypi kernel: [ 0.026256] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 0.029298] pinctrl core: initialized pinctrl subsystem
Aug 7 16:16:26 raspberrypi kernel: [ 0.030476] NET: Registered protocol family 16
Aug 7 16:16:26 raspberrypi kernel: [ 0.034482] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Aug 7 16:16:26 raspberrypi kernel: [ 0.040632] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Aug 7 16:16:26 raspberrypi kernel: [ 0.040673] hw-breakpoint: maximum watchpoint size is 8 bytes.
Aug 7 16:16:26 raspberrypi kernel: [ 0.040912] Serial: AMBA PL011 UART driver
Aug 7 16:16:26 raspberrypi kernel: [ 0.043024] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Aug 7 16:16:26 raspberrypi kernel: [ 0.060074] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-06-19 15:45, variant start_x
Aug 7 16:16:26 raspberrypi kernel: [ 0.070088] raspberrypi-firmware soc:firmware: Firmware hash is 31eda665dcc45e61650a2ef018ef2cf94091c46f
Aug 7 16:16:26 raspberrypi kernel: [ 0.120521] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
Aug 7 16:16:26 raspberrypi kernel: [ 0.122675] SCSI subsystem initialized
Aug 7 16:16:26 raspberrypi kernel: [ 0.122941] usbcore: registered new interface driver usbfs
Aug 7 16:16:26 raspberrypi kernel: [ 0.123034] usbcore: registered new interface driver hub
Aug 7 16:16:26 raspberrypi kernel: [ 0.123180] usbcore: registered new device driver usb
Aug 7 16:16:26 raspberrypi kernel: [ 0.125134] clocksource: Switched to clocksource arch_sys_counter
Aug 7 16:16:26 raspberrypi kernel: [ 1.281379] VFS: Disk quotas dquot_6.6.0
Aug 7 16:16:26 raspberrypi kernel: [ 1.281521] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 7 16:16:26 raspberrypi kernel: [ 1.281723] FS-Cache: Loaded
Aug 7 16:16:26 raspberrypi kernel: [ 1.282000] CacheFiles: Loaded
Aug 7 16:16:26 raspberrypi kernel: [ 1.292795] thermal_sys: Registered thermal governor 'step_wise'
Aug 7 16:16:26 raspberrypi kernel: [ 1.293167] NET: Registered protocol family 2
Aug 7 16:16:26 raspberrypi kernel: [ 1.294210] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 1.294278] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 1.294420] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 1.294630] TCP: Hash tables configured (established 8192 bind 8192)
Aug 7 16:16:26 raspberrypi kernel: [ 1.294804] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 1.294877] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
Aug 7 16:16:26 raspberrypi kernel: [ 1.295613] NET: Registered protocol family 1
Aug 7 16:16:26 raspberrypi kernel: [ 1.296329] RPC: Registered named UNIX socket transport module.
Aug 7 16:16:26 raspberrypi kernel: [ 1.296360] RPC: Registered udp transport module.
Aug 7 16:16:26 raspberrypi kernel: [ 1.296387] RPC: Registered tcp transport module.
Aug 7 16:16:26 raspberrypi kernel: [ 1.296413] RPC: Registered tcp NFSv4.1 backchannel transport module.
Aug 7 16:16:26 raspberrypi kernel: [ 1.298159] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Aug 7 16:16:26 raspberrypi kernel: [ 1.301384] Initialise system trusted keyrings
Aug 7 16:16:26 raspberrypi kernel: [ 1.301649] workingset: timestamp_bits=30 max_order=18 bucket_order=0
Aug 7 16:16:26 raspberrypi kernel: [ 1.312049] FS-Cache: Netfs 'nfs' registered for caching
Aug 7 16:16:26 raspberrypi kernel: [ 1.312695] NFS: Registering the id_resolver key type
Aug 7 16:16:26 raspberrypi kernel: [ 1.312759] Key type id_resolver registered
Aug 7 16:16:26 raspberrypi kernel: [ 1.312785] Key type id_legacy registered
Aug 7 16:16:26 raspberrypi kernel: [ 1.312821] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Aug 7 16:16:26 raspberrypi kernel: [ 1.314057] Key type asymmetric registered
Aug 7 16:16:26 raspberrypi kernel: [ 1.314087] Asymmetric key parser 'x509' registered
Aug 7 16:16:26 raspberrypi kernel: [ 1.314153] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
Aug 7 16:16:26 raspberrypi kernel: [ 1.314190] io scheduler mq-deadline registered
Aug 7 16:16:26 raspberrypi kernel: [ 1.314217] io scheduler kyber registered
Aug 7 16:16:26 raspberrypi kernel: [ 1.317639] bcm2708_fb soc:fb: FB found 1 display(s)
Aug 7 16:16:26 raspberrypi kernel: [ 1.378670] Console: switching to colour frame buffer device 228x61
Aug 7 16:16:26 raspberrypi kernel: [ 1.407421] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1824x984
Aug 7 16:16:26 raspberrypi kernel: [ 1.411239] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
Aug 7 16:16:26 raspberrypi kernel: [ 1.413524] bcm2835-rng 3f104000.rng: hwrng registered
Aug 7 16:16:26 raspberrypi kernel: [ 1.414196] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Aug 7 16:16:26 raspberrypi kernel: [ 1.415189] vc-sm: Videocore shared memory driver
Aug 7 16:16:26 raspberrypi kernel: [ 1.415827] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Aug 7 16:16:26 raspberrypi kernel: [ 1.427748] brd: module loaded
Aug 7 16:16:26 raspberrypi kernel: [ 1.439807] loop: module loaded
Aug 7 16:16:26 raspberrypi kernel: [ 1.441333] Loading iSCSI transport class v2.0-870.
Aug 7 16:16:26 raspberrypi kernel: [ 1.442349] libphy: Fixed MDIO Bus: probed
Aug 7 16:16:26 raspberrypi kernel: [ 1.442590] usbcore: registered new interface driver lan78xx
Aug 7 16:16:26 raspberrypi kernel: [ 1.442833] usbcore: registered new interface driver smsc95xx
Aug 7 16:16:26 raspberrypi kernel: [ 1.443022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Aug 7 16:16:26 raspberrypi kernel: [ 2.171451] Core Release: 2.80a
Aug 7 16:16:26 raspberrypi kernel: [ 2.171565] Setting default values for core params
Aug 7 16:16:26 raspberrypi kernel: [ 2.171741] Finished setting default values for core params
Aug 7 16:16:26 raspberrypi kernel: [ 2.372303] Using Buffer DMA mode
Aug 7 16:16:26 raspberrypi kernel: [ 2.372418] Periodic Transfer Interrupt Enhancement - disabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.372593] Multiprocessor Interrupt Enhancement - disabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.372763] OTG VER PARAM: 0, OTG VER FLAG: 0
Aug 7 16:16:26 raspberrypi kernel: [ 2.372914] Dedicated Tx FIFOs mode
Aug 7 16:16:26 raspberrypi kernel: [ 2.373722] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b4114000 dma = 0xf4114000 len=9024
Aug 7 16:16:26 raspberrypi kernel: [ 2.374021] FIQ FSM acceleration enabled for :
Aug 7 16:16:26 raspberrypi kernel: [ 2.374021] Non-periodic Split Transactions
Aug 7 16:16:26 raspberrypi kernel: [ 2.374021] Periodic Split Transactions
Aug 7 16:16:26 raspberrypi kernel: [ 2.374021] High-Speed Isochronous Endpoints
Aug 7 16:16:26 raspberrypi kernel: [ 2.374021] Interrupt/Control Split Transaction hack enabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.389027] dwc_otg: Microframe scheduler enabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.389093] WARN::hcd_init_fiq:457: FIQ on core 1
Aug 7 16:16:26 raspberrypi kernel: [ 2.396369] WARN::hcd_init_fiq:458: FIQ ASM at 806bc490 length 36
Aug 7 16:16:26 raspberrypi kernel: [ 2.403523] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
Aug 7 16:16:26 raspberrypi kernel: [ 2.410689] dwc_otg 3f980000.usb: DWC OTG Controller
Aug 7 16:16:26 raspberrypi kernel: [ 2.417817] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Aug 7 16:16:26 raspberrypi kernel: [ 2.424921] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
Aug 7 16:16:26 raspberrypi kernel: [ 2.432042] Init: Port Power? op_state=1
Aug 7 16:16:26 raspberrypi kernel: [ 2.438970] Init: Power Port (0)
Aug 7 16:16:26 raspberrypi kernel: [ 2.446282] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Aug 7 16:16:26 raspberrypi kernel: [ 2.453370] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 7 16:16:26 raspberrypi kernel: [ 2.460620] usb usb1: Product: DWC OTG Controller
Aug 7 16:16:26 raspberrypi kernel: [ 2.467835] usb usb1: Manufacturer: Linux 5.4.47-v7+ dwc_otg_hcd
Aug 7 16:16:26 raspberrypi kernel: [ 2.474965] usb usb1: SerialNumber: 3f980000.usb
Aug 7 16:16:26 raspberrypi kernel: [ 2.482760] hub 1-0:1.0: USB hub found
Aug 7 16:16:26 raspberrypi kernel: [ 2.489840] hub 1-0:1.0: 1 port detected
Aug 7 16:16:26 raspberrypi kernel: [ 2.497609] dwc_otg: FIQ enabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.497619] dwc_otg: NAK holdoff enabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.497629] dwc_otg: FIQ split-transaction FSM enabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.497643] Module dwc_common_port init
Aug 7 16:16:26 raspberrypi kernel: [ 2.497989] usbcore: registered new interface driver usb-storage
Aug 7 16:16:26 raspberrypi kernel: [ 2.505319] mousedev: PS/2 mouse device common for all mice
Aug 7 16:16:26 raspberrypi kernel: [ 2.513843] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Aug 7 16:16:26 raspberrypi kernel: [ 2.522493] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 600000 KHz
Aug 7 16:16:26 raspberrypi kernel: [ 2.531116] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 700000 KHz
Aug 7 16:16:26 raspberrypi kernel: [ 2.537950] sdhci: Secure Digital Host Controller Interface driver
Aug 7 16:16:26 raspberrypi kernel: [ 2.544190] sdhci: Copyright(c) Pierre Ossman
Aug 7 16:16:26 raspberrypi kernel: [ 2.551021] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
Aug 7 16:16:26 raspberrypi kernel: [ 2.557789] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Aug 7 16:16:26 raspberrypi kernel: [ 2.564243] sdhci-pltfm: SDHCI platform and OF driver helper
Aug 7 16:16:26 raspberrypi kernel: [ 2.572091] ledtrig-cpu: registered to indicate activity on CPUs
Aug 7 16:16:26 raspberrypi kernel: [ 2.578593] hidraw: raw HID events driver (C) Jiri Kosina
Aug 7 16:16:26 raspberrypi kernel: [ 2.585086] usbcore: registered new interface driver usbhid
Aug 7 16:16:26 raspberrypi kernel: [ 2.591377] usbhid: USB HID core driver
Aug 7 16:16:26 raspberrypi kernel: [ 2.598575] vchiq: vchiq_init_state: slot_zero = (ptrval)
Aug 7 16:16:26 raspberrypi kernel: [ 2.606344] [vc_sm_connected_init]: start
Aug 7 16:16:26 raspberrypi kernel: [ 2.615104] [vc_sm_connected_init]: end - returning 0
Aug 7 16:16:26 raspberrypi kernel: [ 2.622755] Initializing XFRM netlink socket
Aug 7 16:16:26 raspberrypi kernel: [ 2.628859] NET: Registered protocol family 17
Aug 7 16:16:26 raspberrypi kernel: [ 2.634926] Key type dns_resolver registered
Aug 7 16:16:26 raspberrypi kernel: [ 2.641399] Registering SWP/SWPB emulation handler
Aug 7 16:16:26 raspberrypi kernel: [ 2.647670] registered taskstats version 1
Aug 7 16:16:26 raspberrypi kernel: [ 2.653511] Loading compiled-in X.509 certificates
Aug 7 16:16:26 raspberrypi kernel: [ 2.659889] Key type ._fscrypt registered
Aug 7 16:16:26 raspberrypi kernel: [ 2.665826] Key type .fscrypt registered
Aug 7 16:16:26 raspberrypi kernel: [ 2.681059] uart-pl011 3f201000.serial: cts_event_workaround enabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.687146] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
Aug 7 16:16:26 raspberrypi kernel: [ 2.695378] printk: console [ttyS0] disabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.701518] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 53, base_baud = 50000000) is a 16550
Aug 7 16:16:26 raspberrypi kernel: [ 2.715292] Indeed it is in host mode hprt0 = 00021501
Aug 7 16:16:26 raspberrypi kernel: [ 2.726471] printk: console [ttyS0] enabled
Aug 7 16:16:26 raspberrypi kernel: [ 2.955162] usb 1-1: new high-speed USB device number 2 using dwc_otg
Aug 7 16:16:26 raspberrypi kernel: [ 2.975731] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Aug 7 16:16:26 raspberrypi kernel: [ 2.986819] Indeed it is in host mode hprt0 = 00001101
Aug 7 16:16:26 raspberrypi kernel: [ 2.993090] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
Aug 7 16:16:26 raspberrypi kernel: [ 3.246841] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 7 16:16:26 raspberrypi kernel: [ 3.253344] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
Aug 7 16:16:26 raspberrypi kernel: [ 3.261557] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 7 16:16:26 raspberrypi kernel: [ 3.266885] random: fast init done
Aug 7 16:16:26 raspberrypi kernel: [ 3.843005] hub 1-1:1.0: USB hub found
Aug 7 16:16:26 raspberrypi kernel: [ 3.853363] hub 1-1:1.0: 4 ports detected
Aug 7 16:16:26 raspberrypi kernel: [ 3.864050] sdhost: log_buf @ (ptrval) (f4113000)
Aug 7 16:16:26 raspberrypi kernel: [ 3.905589] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Aug 7 16:16:26 raspberrypi kernel: [ 3.919264] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Aug 7 16:16:26 raspberrypi kernel: [ 3.931208] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Aug 7 16:16:26 raspberrypi kernel: [ 3.945444] of_cfs_init
Aug 7 16:16:26 raspberrypi kernel: [ 3.954296] of_cfs_init: OK
Aug 7 16:16:26 raspberrypi kernel: [ 3.964350] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Aug 7 16:16:26 raspberrypi kernel: [ 3.964533] Waiting for root device /dev/mmcblk0p7...
Aug 7 16:16:26 raspberrypi kernel: [ 3.979245] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Aug 7 16:16:26 raspberrypi kernel: [ 4.061120] mmc0: host does not support reading read-only switch, assuming write-enable
Aug 7 16:16:26 raspberrypi kernel: [ 4.078739] mmc1: new high speed SDIO card at address 0001
Aug 7 16:16:26 raspberrypi kernel: [ 4.096493] mmc0: new high speed SDHC card at address aaaa
Aug 7 16:16:26 raspberrypi kernel: [ 4.109204] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
Aug 7 16:16:26 raspberrypi kernel: [ 4.127328] mmcblk0: p1 p2 < p5 p6 p7 >
Aug 7 16:16:26 raspberrypi kernel: [ 4.170218] EXT4-fs (mmcblk0p7): INFO: recovery required on readonly filesystem
Aug 7 16:16:26 raspberrypi kernel: [ 4.184100] EXT4-fs (mmcblk0p7): write access will be enabled during recovery
Aug 7 16:16:26 raspberrypi kernel: [ 4.205178] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Aug 7 16:16:26 raspberrypi kernel: [ 4.224774] EXT4-fs (mmcblk0p7): recovery complete
Aug 7 16:16:26 raspberrypi kernel: [ 4.240245] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Aug 7 16:16:26 raspberrypi kernel: [ 4.254954] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
Aug 7 16:16:26 raspberrypi kernel: [ 4.278295] devtmpfs: mounted
Aug 7 16:16:26 raspberrypi kernel: [ 4.293546] Freeing unused kernel memory: 1024K
Aug 7 16:16:26 raspberrypi kernel: [ 4.304797] Run /sbin/init as init process
Aug 7 16:16:26 raspberrypi kernel: [ 4.345532] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
Aug 7 16:16:26 raspberrypi kernel: [ 4.360529] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 7 16:16:26 raspberrypi kernel: [ 4.375180] hub 1-1.1:1.0: USB hub found
Aug 7 16:16:26 raspberrypi kernel: [ 4.385728] hub 1-1.1:1.0: 3 ports detected
Aug 7 16:16:26 raspberrypi kernel: [ 4.715190] usb 1-1.1.2: new low-speed USB device number 4 using dwc_otg
Aug 7 16:16:26 raspberrypi kernel: [ 4.891976] usb 1-1.1.2: New USB device found, idVendor=1ea7, idProduct=0002, bcdDevice= 2.00
Aug 7 16:16:26 raspberrypi kernel: [ 4.900275] NET: Registered protocol family 10
Aug 7 16:16:26 raspberrypi kernel: [ 4.907308] usb 1-1.1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 7 16:16:26 raspberrypi kernel: [ 4.919501] Segment Routing with IPv6
Aug 7 16:16:26 raspberrypi kernel: [ 4.932470] usb 1-1.1.2: Product: 2.4GHz Keyboard & Mouse Combo
Aug 7 16:16:26 raspberrypi kernel: [ 4.967784] input: 2.4GHz Keyboard & Mouse Combo as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/0003:1EA7:0002.0001/input/input0
Aug 7 16:16:26 raspberrypi kernel: [ 5.003040] random: systemd: uninitialized urandom read (16 bytes read)
Aug 7 16:16:26 raspberrypi kernel: [ 5.055924] hid-generic 0003:1EA7:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [2.4GHz Keyboard & Mouse Combo] on usb-3f980000.usb-1.1.2/input0
Aug 7 16:16:26 raspberrypi kernel: [ 5.103123] input: 2.4GHz Keyboard & Mouse Combo as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:1EA7:0002.0002/input/input1
Aug 7 16:16:26 raspberrypi kernel: [ 5.125491] input: 2.4GHz Keyboard & Mouse Combo Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:1EA7:0002.0002/input/input2
Aug 7 16:16:26 raspberrypi kernel: [ 5.163159] input: 2.4GHz Keyboard & Mouse Combo Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:1EA7:0002.0002/input/input3
Aug 7 16:16:26 raspberrypi kernel: [ 5.225355] input: 2.4GHz Keyboard & Mouse Combo System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:1EA7:0002.0002/input/input4
Aug 7 16:16:26 raspberrypi kernel: [ 5.225790] hid-generic 0003:1EA7:0002.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [2.4GHz Keyboard & Mouse Combo] on usb-3f980000.usb-1.1.2/input1
Aug 7 16:16:26 raspberrypi kernel: [ 5.319480] random: systemd: uninitialized urandom read (16 bytes read)
Aug 7 16:16:26 raspberrypi kernel: [ 5.325300] usb 1-1.1.3: new full-speed USB device number 5 using dwc_otg
Aug 7 16:16:26 raspberrypi kernel: [ 5.382939] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
Aug 7 16:16:26 raspberrypi kernel: [ 5.498580] usb 1-1.1.3: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
Aug 7 16:16:26 raspberrypi kernel: [ 5.516486] usb 1-1.1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 7 16:16:26 raspberrypi kernel: [ 5.825260] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
Aug 7 16:16:26 raspberrypi kernel: [ 5.975685] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
Aug 7 16:16:26 raspberrypi kernel: [ 5.994241] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 7 16:16:26 raspberrypi kernel: [ 6.217255] i2c /dev entries driver
Aug 7 16:16:26 raspberrypi kernel: [ 6.293141] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
Aug 7 16:16:26 raspberrypi kernel: [ 6.314793] libphy: lan78xx-mdiobus: probed
