Une fois arrivé à l'étape d'installation apache myqsl, j'utilise le code suivant
apt-get install mysql-server apache2 php5Code : Tout sélectionner
Reading package lists... Done
Building dependency tree
Reading state information... Done
apache2 is already the newest version.
mysql-server is already the newest version.
php5 is already the newest version.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
mysql-server : Depends: mysql-server-5.5 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
root@raspberrypi:~# Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
-bash: syntax error near unexpected token `('
