[Résolu] Transmission 403 forbidden  [RESOLU]
BrunoGee
Message par BrunoGee » jeu. 22 sept. 2016 12:06
Surement une erreur de jeunesse, mais impossible à la trouver...
J'ai fait un
sudo apt-get install transmission-daemon
Puis, j'ai modifié le /etc/transmission-daemon/settings.json
que voici en entier :
    "alt-speed-down": 50,
    "alt-speed-enabled": false,
    "alt-speed-time-begin": 540,
    "alt-speed-time-day": 127,
    "alt-speed-time-enabled": false,
    "alt-speed-time-end": 1020,
    "alt-speed-up": 50,
    "bind-address-ipv4": "0.0.0.0",
    "bind-address-ipv6": "::",
    "blocklist-enabled": false,
    "blocklist-url": " http://list.iblocklist.com/?list=bt_level1&fileformat=p2p&archiveformat=gz",
    "cache-size-mb": 4,
    "dht-enabled": true,
    "download-dir": "/home/pi/Downloads",
    "download-queue-enabled": true,
    "download-queue-size": 5,
    "encryption": 1,
    "idle-seeding-limit": 30,
    "idle-seeding-limit-enabled": false,
    "incomplete-dir": "/home/pi/Downloads",
    "incomplete-dir-enabled": true,
    "lpd-enabled": false,
    "message-level": 1,
    "peer-congestion-algorithm": "",
    "peer-id-ttl-hours": 6,
    "peer-limit-global": 200,
    "peer-limit-per-torrent": 50,
    "peer-port": 51435,
    "peer-port-random-high": 65535,
    "peer-port-random-low": 49152,
    "peer-port-random-on-start": false,
    "peer-socket-tos": "default",
    "pex-enabled": true,
    "port-forwarding-enabled": true,
    "preallocation": 1,
    "prefetch-enabled": 1,
    "queue-stalled-enabled": true,
    "queue-stalled-minutes": 30,
    "ratio-limit": 2,
    "ratio-limit-enabled": false,
    "rename-partial-files": true,
    "rpc-authentication-required": false,
    "rpc-bind-address": "0.0.0.0",
    "rpc-enabled": true,
    "rpc-password": "{0bfdfc5fcfd3bf1bc1b6f99f21ce2dc16e5998ffnemRVrIz",
    "rpc-port": 9091,
    "rpc-url": "/transmission/",
    "rpc-username": "pi",
    "rpc-whitelist": "127.0.0.1,192.168.1.*",
    "rpc-whitelist-enabled": false,
    "scrape-paused-torrents-enabled": true,
    "script-torrent-done-enabled": false,
    "script-torrent-done-filename": "",
    "seed-queue-enabled": false,
    "seed-queue-size": 10,
    "speed-limit-down": 100,
    "speed-limit-down-enabled": false,
    "speed-limit-up": 100,
    "speed-limit-up-enabled": false,
    "start-added-torrents": true,
    "trash-original-torrent-files": false,
    "umask": 18,
    "upload-slots-per-torrent": 14,
    "utp-enabled": true
Une idée ?
Une piste ?
Modifié en dernier par BrunoGee le sam. 24 sept. 2016 03:38, modifié 1 fois.
maxty01
Re: Transmission 403 forbidden
Message par maxty01 » jeu. 22 sept. 2016 22:27
Alors bonne nouvelle ton serveur web fonctionne, cependant, tu as un problème de permission.
Regarde les droits des différents fichier du service web.
Je ne peux pas t'en dire plus pour le moment, je ne connais pas bien transmission.
Bonne soirée,
BrunoGee
Message par BrunoGee » jeu. 22 sept. 2016 23:10
Bonjour maxty01,
Ouiiiii :D
Le serveur web fonctionne, il doit y avoir un problème de configuration et je ne retrouve pas le fichier de conf d'origine... pour voir où se situe l'erreur :oops:
Message par domi » ven. 23 sept. 2016 07:36
Comme le souligne Maxty01, je pense qu'il s'agit plutôt d'un problème de droits d'accès sur un fichier.
L'erreur 403 veut dire que le serveur Web ne peut pas lire un fichier dont il a besoin. le fichier est présent, mais pas autorisé au serveur Web.
BrunoGee
Message par BrunoGee » sam. 24 sept. 2016 00:55
Lorsque je suis sur la framboise, le localhost:9091fonctionne pourtant bien...
BrunoGee
Re: [Résolu] Transmission 403 forbidden  [RESOLU]
Message par BrunoGee » sam. 24 sept. 2016 03:42
Ayé :D
J'ai trouvé :D
Pour résumer :
Mon raspberry pi est bien sous raspbian jessie
Transmission est en version 2.84-0.2
et le fichier de configuration qui est utilisé n'est pas /etc/transmission-daemon/settings.json
mais /home/pi/.config/transmission-daemon/setting.json
J'avais donc beau modifier le premier, ça ne servait à rien :roll:
