J'ai lancé sur raspbian (direct sans noos) un
sudo apt-get update && sudo apt-get upgrade
après avoir mouliné je reçois ce message auquel je ne comprends rien:
xorg-server (2:1.18.3-2) unstable; urgency=medium
X now defaults to using built-in modesetting video driver on Intel
hardware which is "4th gen GMA" and newer, so roughly speaking on hardware
from 2007 and up. If this triggers new bugs on your hw, please file them
against the xserver.
Continuing to use the -intel driver is possible by dropping the template
xorg.conf to /etc/X11:
# cp /usr/share/doc/xserver-xorg-video-intel/xorg.conf /etc/X11
-- Timo Aaltonen <tjaalton@debian.org> Tue, 19 Jul 2016 04:28:05 +0300
xorg-server (2:1.17.3-1) unstable; urgency=medium
The Xorg server is no longer setuid root by default. This change reduces the
risk of privilege escalation due to X server bugs, but has some side effects:
* it relies on logind and libpam-systemd
* it relies on a kernel video driver (so the userspace component doesn't
touch the hardware directly)
* it needs X to run on the virtual console (VT) it was started from
* it changes the location for storing the Xorg log from /var/log/ to
~/.local/share/xorg/
On systems where those are not available, the new xserver-xorg-legacy package
is needed to allow X to run with elevated privileges. See the
Xwrapper.config(5) manual page for configuration details.
-- Julien Cristau <jcristau@debian.org> Tue, 27 Oct 2015 22:54:11 +0000
(q to quit)
Alexidreaming
Re: The Xorg server is no longer setuid root by default
Salut, tu as demandé à Raspbian de démarrer en mode console ou en mode graphique(bureau)?
Si tu es en mode texte, essaye de lancer.
startxLe pro du déterrage de topic est là!
Alexidreaming
Alexidreaming
Ghislain
J'ai eu la meme maj hier sur un upgrade, en gros Xorg n'a pas les privileges root pour protéger le système
Alexidreaming
Essaye quand même et dis-moi
Alexidreaming
Alexidreaming
Ghislain
Meme en boot console ça fait la maj (normal) donc pas de soucis
Merci à tous
en fait en refaissant une nouvelle MAJ la semaine suivante, tout est revenu dans l'ordre
