[Résolu]Problème de performance avec mes RPi 3A+ sous Bullseye !
Re: Problème de performance avec mes RPi 3A+ sous Bullseye !
Message par Artemus24 » jeu. 5 janv. 2023 13:55
Voici les tests que Dyox m'avait demandé de faire :
~> dmesg -e
[janv. 5 12:23] Booting Linux on physical CPU 0x0
[  +0,000000] Linux version 5.15.76-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1597 SMP Fri Nov 4 12:13:17 GMT 2022
[  +0,000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[  +0,000000] CPU: div instructions available: patching division code
[  +0,000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[  +0,000000] OF: fdt: Machine model: Raspberry Pi 3 Model A Plus Rev 1.0
[  +0,000000] random: crng init done
[  +0,000000] Memory policy: Data cache writealloc
[  +0,000000] Reserved memory: created CMA memory pool at 0x17c00000, size 64 MiB
[  +0,000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[  +0,000000] Zone ranges:
[  +0,000000]   DMA      [mem 0x0000000000000000-0x000000001bffffff]
[  +0,000000]   Normal   empty
[  +0,000000] Movable zone start for each node
[  +0,000000] Early memory node ranges
[  +0,000000]   node   0: [mem 0x0000000000000000-0x000000001bffffff]
[  +0,000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff]
[  +0,000000] percpu: Embedded 16 pages/cpu s35724 r8192 d21620 u65536
[  +0,000000] pcpu-alloc: s35724 r8192 d21620 u65536 alloc=16*4096
[  +0,000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[  +0,000000] Built 1 zonelists, mobility grouping on.  Total pages: 113680
[  +0,000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=9cba179a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles net.ifnames=0 ip=169.254.1.1
[  +0,000000] Kernel parameter elevator= does not have any effect anymore.
              Please use sysfs to set IO scheduler for individual devices.
[  +0,000000] Unknown kernel command line parameters "splash", will be passed to user space.
[  +0,000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[  +0,000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[  +0,000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[  +0,000000] Memory: 370980K/458752K available (10240K kernel code, 1337K rwdata, 3080K rodata, 1024K init, 569K bss, 22236K reserved, 65536K cma-reserved)
[  +0,000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[  +0,000000] ftrace: allocating 33307 entries in 98 pages
[  +0,000000] ftrace: allocated 98 pages with 3 groups
[  +0,000000] trace event string verifier disabled
[  +0,000000] rcu: Hierarchical RCU implementation.
[  +0,000000]   Rude variant of Tasks RCU enabled.
[  +0,000000]   Tracing variant of Tasks RCU enabled.
[  +0,000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[  +0,000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[  +0,000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[  +0,000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[  +0,000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[  +0,000020] Switching to timer-based delay loop, resolution 52ns
[  +0,000401] Console: colour dummy device 80x30
[  +0,000072] printk: console [tty1] enabled
[  +0,000056] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[  +0,000030] pid_max: default: 32768 minimum: 301
[  +0,000160] LSM: Security Framework initializing
[  +0,000227] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[  +0,000025] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[  +0,001532] cgroup: Disabling memory control group subsystem
[  +0,000284] CPU: Testing write buffer coherency: ok
[  +0,000536] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[  +0,001478] Setting up static identity map for 0x100000 - 0x10003c
[  +0,000189] rcu: Hierarchical SRCU implementation.
[  +0,000989] smp: Bringing up secondary CPUs ...
[  +0,001157] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[  +0,001307] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[  +0,001209] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[  +0,000161] smp: Brought up 1 node, 4 CPUs
[  +0,000083] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[  +0,000019] CPU: All CPU(s) started in HYP mode.
[  +0,000011] CPU: Virtualization extensions available.
[  +0,000847] devtmpfs: initialized
[  +0,018614] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[  +0,000228] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[  +0,000037] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[  +0,003250] pinctrl core: initialized pinctrl subsystem
[  +0,001354] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[  +0,004823] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[  +0,005568] audit: initializing netlink subsys (disabled)
[  +0,000298] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[  +0,000634] thermal_sys: Registered thermal governor 'step_wise'
[  +0,001274] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[  +0,000020] hw-breakpoint: maximum watchpoint size is 8 bytes.
[  +0,000267] Serial: AMBA PL011 UART driver
[  +0,007855] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[  +0,025059] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-10-26T11:10:35, variant start
[  +0,010016] raspberrypi-firmware soc:firmware: Firmware hash is c72ad6b26ff40c91ef776b847436094ee63fabee
[  +0,049689] Kprobes globally optimized
[  +0,005445] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[  +0,002229] SCSI subsystem initialized
[  +0,000275] usbcore: registered new interface driver usbfs
[  +0,000065] usbcore: registered new interface driver hub
[  +0,000072] usbcore: registered new device driver usb
[  +0,000315] usb_phy_generic phy: supply vcc not found, using dummy regulator
[  +0,000198] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[  +0,000268] pps_core: LinuxPPS API ver. 1 registered
[  +0,000015] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[  +0,000030] PTP clock support registered
[  +0,002588] clocksource: Switched to clocksource arch_sys_counter
[  +0,070725] VFS: Disk quotas dquot_6.6.0
[  +0,000120] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[  +0,000205] FS-Cache: Loaded
[  +0,000287] CacheFiles: Loaded
[  +0,011086] NET: Registered PF_INET protocol family
[  +0,000223] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[  +0,001299] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[  +0,000046] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[  +0,000028] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[  +0,000073] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[  +0,000108] TCP: Hash tables configured (established 4096 bind 4096)
[  +0,000138] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[  +0,000043] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[  +0,000272] NET: Registered PF_UNIX/PF_LOCAL protocol family
[  +0,006373] RPC: Registered named UNIX socket transport module.
[  +0,000017] RPC: Registered udp transport module.
[  +0,000013] RPC: Registered tcp transport module.
[  +0,000012] RPC: Registered tcp NFSv4.1 backchannel transport module.
[  +1,657039] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[  +0,003821] Initialise system trusted keyrings
[  +0,000357] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[  +0,009981] zbud: loaded
[  +0,002081] FS-Cache: Netfs 'nfs' registered for caching
[  +0,001016] NFS: Registering the id_resolver key type
[  +0,000065] Key type id_resolver registered
[  +0,000014] Key type id_legacy registered
[  +0,000143] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[  +0,000016] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[  +0,001277] Key type asymmetric registered
[  +0,000017] Asymmetric key parser 'x509' registered
[  +0,000098] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[  +0,000017] io scheduler mq-deadline registered
[  +0,000015] io scheduler kyber registered
[  +0,004800] bcm2708_fb soc:fb: FB found 1 display(s)
[  +0,007631] Console: switching to colour frame buffer device 82x26
[  +0,004940] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[  +0,005734] bcm2835-rng 3f104000.rng: hwrng registered
[  +0,000470] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[  +0,001196] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[  +0,012539] brd: module loaded
[  +0,009843] loop: module loaded
[  +0,000658] Loading iSCSI transport class v2.0-870.
[  +0,001914] usbcore: registered new interface driver lan78xx
[  +0,000070] usbcore: registered new interface driver smsc95xx
[  +0,000028] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[  +0,728243] Core Release: 2.80a
[  +0,000021] Setting default values for core params
[  +0,000032] Finished setting default values for core params
[  +0,200355] Using Buffer DMA mode
[  +0,000013] Periodic Transfer Interrupt Enhancement - disabled
[  +0,000013] Multiprocessor Interrupt Enhancement - disabled
[  +0,000013] OTG VER PARAM: 0, OTG VER FLAG: 0
[  +0,000049] Dedicated Tx FIFOs mode
[  +0,000796] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 97d14000 dma = 0xd7d14000 len=9024
[  +0,000043] FIQ FSM acceleration enabled for :
              Non-periodic Split Transactions
              Periodic Split Transactions
              High-Speed Isochronous Endpoints
              Interrupt/Control Split Transaction hack enabled
[  +0,000021] dwc_otg: Microframe scheduler enabled
[  +0,000135] WARN::hcd_init_fiq:457: FIQ on core 1
[  +0,000019] WARN::hcd_init_fiq:458: FIQ ASM at 807fb38c length 36
[  +0,000021] WARN::hcd_init_fiq:497: MPHI regs_base at 9c810000
[  +0,000023] dwc_otg 3f980000.usb: DWC OTG Controller
[  +0,000042] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[  +0,000051] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[  +0,000059] Init: Port Power? op_state=1
[  +0,000012] Init: Power Port (0)
[  +0,000364] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[  +0,000025] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[  +0,000019] usb usb1: Product: DWC OTG Controller
[  +0,000017] usb usb1: Manufacturer: Linux 5.15.76-v7+ dwc_otg_hcd
[  +0,000017] usb usb1: SerialNumber: 3f980000.usb
[  +0,000776] hub 1-0:1.0: USB hub found
[  +0,000069] hub 1-0:1.0: 1 port detected
[  +0,000872] dwc_otg: FIQ enabled
[  +0,000014] dwc_otg: NAK holdoff enabled
[  +0,000012] dwc_otg: FIQ split-transaction FSM enabled
[  +0,000018] Module dwc_common_port init
[  +0,000327] usbcore: registered new interface driver usb-storage
[  +0,000239] mousedev: PS/2 mouse device common for all mice
[  +0,003486] sdhci: Secure Digital Host Controller Interface driver
[  +0,000016] sdhci: Copyright(c) Pierre Ossman
[  +0,000425] sdhci-pltfm: SDHCI platform and OF driver helper
[  +0,002691] ledtrig-cpu: registered to indicate activity on CPUs
[  +0,000342] hid: raw HID events driver (C) Jiri Kosina
[  +0,000154] usbcore: registered new interface driver usbhid
[  +0,000016] usbhid: USB HID core driver
[  +0,005057] Initializing XFRM netlink socket
[  +0,000054] NET: Registered PF_PACKET protocol family
[  +0,000193] Key type dns_resolver registered
[  +0,000944] Registering SWP/SWPB emulation handler
[  +0,000709] registered taskstats version 1
[  +0,000032] Loading compiled-in X.509 certificates
[  +0,000831] Key type ._fscrypt registered
[  +0,000017] Key type .fscrypt registered
[  +0,000013] Key type fscrypt-provisioning registered
[  +0,011721] uart-pl011 3f201000.serial: cts_event_workaround enabled
[  +0,000180] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[  +0,002656] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[  +0,000453] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[  +0,001791] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[  +0,000023] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[  +0,027937] sdhost: log_buf @ d3a4b045 (d7d13000)
[  +0,053246] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[  +0,017618] Indeed it is in host mode hprt0 = 00021501
[  +0,005145] of_cfs_init
[  +0,000167] of_cfs_init: OK
[  +0,037580] mmc0: host does not support reading read-only switch, assuming write-enable
[  +0,003794] mmc0: new high speed SDHC card at address 59b4
[  +0,000660] mmc1: new high speed SDIO card at address 0001
[  +0,000526] mmcblk0: mmc0:59b4 USD   3.75 GiB
[  +0,003541]  mmcblk0: p1
[  +0,000427] mmcblk0: mmc0:59b4 USD   3.75 GiB
[  +0,158015] usb 1-1: new high-speed USB device number 2 using dwc_otg
[  +0,000329] Indeed it is in host mode hprt0 = 00001101
[  +0,241939] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.52
[  +0,000026] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[  +0,000020] usb 1-1: Product: USB2.0 Hub
[  +0,000960] hub 1-1:1.0: USB hub found
[  +0,000368] hub 1-1:1.0: 4 ports detected
[  +0,316351] usb 1-1.4: new high-speed USB device number 3 using dwc_otg
[  +0,132247] usb 1-1.4: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.52
[  +0,000025] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[  +0,000020] usb 1-1.4: Product: USB2.0 Hub
[  +0,000793] hub 1-1.4:1.0: USB hub found
[  +0,000377] hub 1-1.4:1.0: 4 ports detected
[  +1,636785] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[  +0,499754] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[  +0,142545] usb 1-1.3: New USB device found, idVendor=0b95, idProduct=772b, bcdDevice= 0.01
[  +0,000025] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  +0,000020] usb 1-1.3: Product: AX88772B
[  +0,000017] usb 1-1.3: Manufacturer: ASIX Elec. Corp.
[  +0,000016] usb 1-1.3: SerialNumber: B02428
[  +0,287378] usb 1-1.4.3: new high-speed USB device number 5 using dwc_otg
[  +0,211127] usb 1-1.4.3: New USB device found, idVendor=0bc2, idProduct=61b3, bcdDevice=13.06
[  +0,000026] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  +0,000020] usb 1-1.4.3: Product: M3 Portable
[  +0,000016] usb 1-1.4.3: Manufacturer: Seagate
[  +0,000017] usb 1-1.4.3: SerialNumber: 35777E04120000BA
[  +0,000744] usb 1-1.4.3: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[  +0,000023] usb 1-1.4.3: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[  +0,000019] usb-storage 1-1.4.3:1.0: USB Mass Storage device detected
[  +0,000981] scsi host0: usb-storage 1-1.4.3:1.0
[janv. 5 12:24] scsi 0:0:0:0: Direct-Access     Seagate  M3 Portable      1306 PQ: 0 ANSI: 6
[  +0,378619] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[  +0,000546] sd 0:0:0:0: [sda] Write Protect is off
[  +0,000023] sd 0:0:0:0: [sda] Mode Sense: 33 00 00 08
[  +0,000455] sd 0:0:0:0: [sda] No Caching mode page found
[  +0,000186] sd 0:0:0:0: [sda] Assuming drive cache: write through
[  +0,071743]  sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 >
[  +0,003055] sd 0:0:0:0: [sda] Attached SCSI disk
[  +8,015797] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[  +0,000110] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[  +0,025449] devtmpfs: mounted
[  +0,008217] Freeing unused kernel image (initmem) memory: 1024K
[  +0,000541] Run /sbin/init as init process
[  +0,000014]   with arguments:
[  +0,000011]     /sbin/init
[  +0,000011]     splash
[  +0,000012]   with environment:
[  +0,000010]     HOME=/
[  +0,000013]     TERM=linux
[  +1,254052] systemd[1]: System time before build time, advancing clock.
[  +0,447371] NET: Registered PF_INET6 protocol family
[  +0,001790] Segment Routing with IPv6
[  +0,000054] In-situ OAM (IOAM) with IPv6
[  +0,217060] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[  +0,001153] systemd[1]: Detected architecture arm.
[  +0,031423] systemd[1]: Set hostname to <RaspberryPi>.
[  +1,717817] systemd[1]: Configuration file /lib/systemd/system/pulseaudio.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[  +0,576627] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[  +0,719268] systemd[1]: Configuration file /lib/systemd/system/pulseaudio.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[  +0,035990] systemd[1]: Queued start job for default target Graphical Interface.
[  +0,015162] systemd[1]: Created slice system-getty.slice.
[  +0,001626] systemd[1]: Created slice system-modprobe.slice.
[  +0,001249] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[  +0,000927] systemd[1]: Created slice User and Session Slice.
[  +0,000547] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  +0,001532] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  +0,001887] systemd[1]: Reached target Slices.
[  +0,001623] systemd[1]: Listening on Syslog Socket.
[  +0,000786] systemd[1]: Listening on fsck to fsckd communication Socket.
[  +0,000487] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  +0,001398] systemd[1]: Listening on Journal Audit Socket.
[  +0,000842] systemd[1]: Listening on Journal Socket (/dev/log).
[  +0,001068] systemd[1]: Listening on Journal Socket.
[  +0,016860] systemd[1]: Listening on udev Control Socket.
[  +0,001024] systemd[1]: Listening on udev Kernel Socket.
[  +0,001461] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[  +0,004958] systemd[1]: Mounting POSIX Message Queue File System...
[  +0,005743] systemd[1]: Mounting RPC Pipe File System...
[  +0,006404] systemd[1]: Mounting Kernel Debug File System...
[  +0,006367] systemd[1]: Mounting Kernel Trace File System...
[  +0,001488] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[  +0,029741] systemd[1]: Starting Restore / save the current clock...
[  +0,057716] systemd[1]: Starting Set the console keyboard layout...
[  +0,007005] systemd[1]: Starting Create list of static device nodes for the current kernel...
[  +0,006903] systemd[1]: Starting Load Kernel Module configfs...
[  +0,009518] systemd[1]: Starting Load Kernel Module drm...
[  +0,007251] systemd[1]: Starting Load Kernel Module fuse...
[  +0,011741] systemd[1]: Started Nameserver information manager.
[  +0,001666] systemd[1]: Reached target Network (Pre).
[  +0,128139] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[  +0,005561] systemd[1]: Starting File System Check on Root Device...
[  +0,013707] systemd[1]: Starting Journal Service...
[  +0,098238] fuse: init (API version 7.34)
[  +0,017969] systemd[1]: Starting Load Kernel Modules...
[  +0,006811] systemd[1]: Starting Coldplug All udev Devices...
[  +0,013631] systemd[1]: Finished Create list of static device nodes for the current kernel.
[  +0,002018] systemd[1]: modprobe@configfs.service: Succeeded.
[  +0,001422] systemd[1]: Finished Load Kernel Module configfs.
[  +0,001955] systemd[1]: modprobe@fuse.service: Succeeded.
[  +0,001234] systemd[1]: Finished Load Kernel Module fuse.
[  +0,007008] systemd[1]: Mounting FUSE Control File System...
[  +0,011554] systemd[1]: Mounting Kernel Configuration File System...
[  +0,006528] systemd[1]: Started File System Check Daemon to report status.
[  +0,375977] i2c_dev: i2c /dev entries driver
[  +0,006964] systemd[1]: Finished Load Kernel Modules.
[  +0,006599] systemd[1]: Starting Apply Kernel Variables...
[  +0,001163] systemd[1]: Started Journal Service.
[  +1,720824] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
[  +1,769970] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[  +0,010376] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[  +0,000035] [vc_sm_connected_init]: start
[  +0,000845] [vc_sm_connected_init]: installed successfully
[  +0,065434] mc: Linux media interface: v0.10
[  +0,256861] videodev: Linux video capture interface: v2.00
[  +0,248632] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[  +0,008546] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[  +0,000829] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[  +0,136266] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[  +0,013298] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[  +0,000090] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[  +0,002845] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[  +0,000049] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[  +0,003704] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[  +0,000049] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[  +0,012390] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[  +0,000067] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[  +0,007619] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[  +0,000065] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[  +0,007882] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[  +0,052902] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[  +0,044007] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[  +0,000512] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[  +0,000412] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[  +0,000319] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[  +0,000035] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[  +0,000027] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[  +0,000029] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[  +0,000022] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[  +0,023205] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[  +0,000505] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[  +0,000434] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[  +0,000351] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[  +0,000036] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[  +0,000028] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[  +0,000023] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[  +0,000028] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[  +0,000214] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[  +0,057402] usbcore: registered new interface driver uas
[  +0,097727] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  +0,076323] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  +0,029509] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  +0,134880] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[  +0,298857] brcmfmac: F1 signature read @0x18000000=0x15264345
[  +0,017056] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[  +0,000776] usbcore: registered new interface driver brcmfmac
[  +0,253764] Asix Electronics AX88772C usb-001:004:10: attached PHY driver (mii_bus:phy_addr=usb-001:004:10, irq=POLL)
[  +0,001035] asix 1-1.3:1.0 eth0: register 'asix' at usb-3f980000.usb-1.3, ASIX AX88772B USB 2.0 Ethernet, 00:50:b6:b0:24:28
[  +0,000283] usbcore: registered new interface driver asix
[  +0,894782] asix 1-1.3:1.0 eth6: renamed from eth0
[  +0,130775] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[  +0,074077] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[  +1,092664] asix 1-1.3:1.0 eth6: Link is Down
[  +0,486867] Adding 8388604k swap on /dev/sda7.  Priority:-2 extents:1 across:8388604k FS
[  +0,441711] systemd-journald[126]: Received client request to flush runtime journal.
[  +0,618321] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[  +0,569163] IPv6: ADDRCONF(NETDEV_CHANGE): eth6: link becomes ready
[  +0,000440] asix 1-1.3:1.0 eth6: Link is Up - 100Mbps/Full - flow control off
[  +1,570590] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[  +0,318064] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[  +3,646902] uart-pl011 3f201000.serial: no DMA platform data
[  +0,481782] 8021q: 802.1Q VLAN Support v1.8
[  +3,049550] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[  +5,007411] cam-dummy-reg: disabling
[  +1,048546] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  +1,280655] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[  +9,217805] Bluetooth: Core ver 2.22
[  +0,000142] NET: Registered PF_BLUETOOTH protocol family
[  +0,000007] Bluetooth: HCI device and connection manager initialized
[  +0,000511] Bluetooth: HCI socket layer initialized
[  +0,000014] Bluetooth: L2CAP socket layer initialized
[  +0,000025] Bluetooth: SCO socket layer initialized
[  +0,351110] Bluetooth: HCI UART driver ver 2.3
[  +0,000061] Bluetooth: HCI UART protocol H4 registered
[  +0,000267] Bluetooth: HCI UART protocol Three-wire (H5) registered
[  +0,000425] Bluetooth: HCI UART protocol Broadcom registered
[  +4,485901] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  +0,000023] Bluetooth: BNEP filters: protocol multicast
[  +0,000017] Bluetooth: BNEP socket layer initialized
[  +0,063788] NET: Registered PF_ALG protocol family
[  +0,089070] cryptd: max_cpu_qlen set to 1000
[  +4,420704] Bluetooth: RFCOMM TTY layer initialized
[  +0,000040] Bluetooth: RFCOMM socket layer initialized
[  +0,000031] Bluetooth: RFCOMM ver 1.11
[janv. 5 12:26] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Si tu vois des choses bizarres, tu peux me les signaler. Merci Dyox.
~> systemd-analyze
Startup finished in 17.433s (kernel) + 52.266s (userspace) = 1min 9.700s
graphical.target reached after 52.198s in userspace
~> systemd-analyze blame
38.146s upower.service
22.547s hciuart.service
16.882s dhcpcd.service
 9.861s udisks2.service
 9.265s smbd.service
 8.123s nmbd.service
 8.042s polkit.service
 7.819s cups.service
 6.545s ModemManager.service
 6.503s avahi-daemon.service
 6.298s systemd-logind.service
 6.287s wpa_supplicant.service
 5.455s dev-sda2.device
 5.430s packagekit.service
 5.114s glamor-test.service
 5.106s gldriver-test.service
 4.948s rng-tools-debian.service
 4.434s raspi-config.service
 4.332s rsyslog.service
 4.207s systemd-fsck@dev-disk-by\x2dpartuuid-9cba179a\x2d05.service
 3.956s systemd-fsck@dev-disk-by\x2dpartuuid-9cba179a\x2d06.service
 3.369s user@0.service
 3.323s dphys-swapfile.service
 3.288s colord.service
 2.713s bluetooth.service
 2.634s systemd-fsck@dev-disk-by\x2dpartuuid-9cba179a\x2d01.service
 2.377s ssh.service
 2.316s lightdm.service
 2.160s e2scrub_reap.service
 2.077s keyboard-setup.service
 2.053s systemd-fsck@dev-disk-by\x2dpartuuid-9cba179a\x2d03.service
 1.995s triggerhappy.service
 1.583s rpi-eeprom-update.service
 1.486s systemd-fsck-root.service
 1.462s fake-hwclock.service
 1.444s lm-sensors.service
 1.362s plymouth-read-write.service
 1.242s dev-mqueue.mount
 1.237s run-rpc_pipefs.mount
 1.231s sys-kernel-debug.mount
 1.226s sys-kernel-tracing.mount
 1.057s systemd-udev-trigger.service
 1.035s dev-disk-by\x2dpartuuid-9cba179a\x2d07.swap
  944ms networking.service
  913ms user@1000.service
  814ms systemd-remount-fs.service
  796ms sys-fs-fuse-connections.mount
  785ms sys-kernel-config.mount
  760ms modprobe@drm.service
  690ms systemd-udevd.service
  559ms systemd-journald.service
  534ms systemd-tmpfiles-clean.service
  488ms bthelper@hci0.service
  469ms systemd-timesyncd.service
  446ms systemd-tmpfiles-setup.service
  435ms systemd-modules-load.service
  424ms systemd-rfkill.service
  385ms backup.mount
  358ms warehouse.mount
  337ms systemd-sysctl.service
  321ms kmod-static-nodes.service
  316ms modprobe@configfs.service
  303ms modprobe@fuse.service
  227ms nfs-config.service
  220ms systemd-journal-flush.service
  218ms pulseaudio.service
  211ms systemd-sysusers.service
  204ms boot.mount
  198ms systemd-tmpfiles-setup-dev.service
  194ms plymouth-start.service
  192ms ifupdown-pre.service
  167ms systemd-random-seed.service
  162ms share.mount[color=red
  152ms console-setup.service
  140ms systemd-user-sessions.service
  107ms systemd-update-utmp.service
  102ms tmp.mount
  101ms user-runtime-dir@0.service
   97ms rtkit-daemon.service
   74ms var-log.mount
   61ms systemd-update-utmp-runlevel.service
   45ms rc-local.service
   40ms user-runtime-dir@1000.service
   32ms var-tmp.mount
    5ms plymouth-quit-wait.service
lines 50-85/85 (END)
~> systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @52.198s
└─multi-user.target @52.197s
  └─smbd.service @42.930s +9.265s
    └─nmbd.service @34.800s +8.123s
      └─network-online.target @34.793s
        └─dhcpcd.service @17.908s +16.882s
          └─basic.target @17.760s
            └─sockets.target @17.759s
              └─triggerhappy.socket @17.758s
                └─sysinit.target @17.706s
                  └─plymouth-read-write.service @16.342s +1.362s
                    └─local-fs.target @16.316s
                      └─run-user-1000.mount @38.588s
                        └─swap.target @12.840s
                          └─dev-disk-by\x2dpartuuid-9cba179a\x2d07.swap @11.794s +1.035s
                            └─dev-disk-by\x2dpartuuid-9cba179a\x2d07.device @11.788s
Corrdialement
Message par Artemus24 » jeu. 5 janv. 2023 15:13
Je crois que j'ai mélangé deux notions, à savoir le fichier swap et la partition swap. Je repars de zéro !
Je ne veux pas d'un fichier swap mais d'une partition swap.
Je peux me le permettre sur mon disque Maxtor car j'ai suffisamment d'espace de disponible.
J'ai donc créé en fin de disque une partition de 8Go, soit la taille de la ram de ma RPi 4B.
L'application "dphys-swapfile" utilise le fichier swap, ce que je ne veux pas, et donc, je le désinstalle.
Je teste le service :
~> systemctl status dphys-swapfile
● dphys-swapfile.service
     Loaded: masked (Reason: Unit dphys-swapfile.service is masked.)
     Active: inactive (dead)
J'ai aussi supprimé le fichier "/var/swap".
Ma partition swap a été créé et se nomme "/dev/sda7". J'active la partition swap :
~> free
               total       utilisé      libre     partagé tamp/cache   disponible
Mem:         8087980      194040     7656984       19752      236956     7644896
Partition d'échange:          0           0           0
~> swapon /dev/sda7
~> free
Mem:         8087980      253004     7549504       20040      285472     7585028
Partition d'échange:    8388604           0     8388604
Je redémarre ma raspberry et je constate que l'espace alloué pour free est de nouveau à zero.
Question : Comment faire en sorte que la partition swap soit toujours active ?
Artemus24.
Message par Artemus24 » jeu. 5 janv. 2023 15:40
Je ne sais pas trop ce que j'ai fait, mais en retestant sous RPi 3A+, le free me donne bien mes 8Go.
Je n'ai pas eu besoin, cette fois-ci, de lancer manuellement la commande "swapon /dev/sda7".
Passer par une partition swap aulieu du fichier swap (dphys-swapfile), me donne une excellente fludité avec ma RPi 3A+.
Je suppose que mon problème est résolu.
En résumé deux conneries :
a) ne pas utiliser une partiton swap est une mauvaise idée.
b) ne pas confondre fichier swap (dphys-swapfile) avec partition swap.
Les performances ne sont pas les mêmes.
Et donc, ne pas utiliser "dphys-swapfile".
Je vais pouvoir maintenant bidouiller sur ma Pimoroni que je vais à nouveau réinstaller sur ma RPi 3A+. :D
Artemus24.
Message par destroyedlolo » ven. 6 janv. 2023 10:23
Salut et bonne année,
Je vois que les process de qualité sont toujours aussi bon chez Ubuntu et à la fondation :mrgreen:
Alors non, il n'est pas obligatoire d'avoir une partition de swap. C'était le cas sous HP-UX ou Solaris (je ne me souviens plus) qui y faisait des préallocation, mais pas sous Linux et mes beaucoup de mes machines n'en ont pas et s'en portent pas plus mal.
Après, j'ai cru comprendre que tu n'as "que" 512Go de RAM sur ce PI3 : c'est vrai que c'est limite suivante le DE qu'il est utilisé (et Ubuntu ne fait JAMAIS les bons choix de ce coté). Plutôt que Gnome, Mate ou je ne sais quoi, je te conseillerai d'utiliser des DE plus léger comme LXDE qui est le plus économe mais est un peu rustre. XFCE est plus en ligne avec l'expérience qu'ont peu avoir sur un Gnome mais restant sobre niveau mémoire. Il y en a d'autres encore plus léger mais je ne sais pas s'ils sont packagés pour ton PI.
C'est peut etre d'ailleurs XFCE qui est déjà utilisé avec RasberryOS, je ne sais pas, je n'utilise pas.
Ce qui est très inquiétant, c'est ca.
Artemus24 a écrit :
jeu. 5 janv. 2023 12:39
~> free -h
Mem:           427Mi       133Mi       159Mi       8,0Mi       134Mi       234Mi
Partition d'échange:      8,0Gi       229Mi       7,8Gi
Si c'est après le boot, t'as clairement un process qui bouffe beaucoup trop de mémoire :
  • trop de mémoire utilisée car le système a déjà commencé à swapper, sinon la swap serait à 0 d'utilisation AU BOOT (ensuite, c'est normal que ça augmente car le système va virer de la mémoire les processes qui sont lancés mais jamais utilisés, pour libérer de la mémoire pour le cache disque)
  • ce n'est que transitoire car il te reste pas mal de place libre dans la mémoire physique et les caches sont relativement gros
Le plus simple est évidemment de passer sur un vrai OS adapté a ta config.
Sinon, si tu veux t'acharner avec Ubuntu, il doit y avoir quelque chose de glouton lancé au boot, pas forcément lié au DE (par exemple, s'il vérifie s'il y a une update en attente).
Sinon, selon ce que tu veux faire, est-ce que X est vraiment nécessaire ?
Enfin, le fait que sans fichier swap, tu n'arrives même plus a t'y logger indique clairement que le système est soit totalement planté, soit tourne en boucle pour essayer de libérer de la mémoire (ça m'arrive malheureusement lorsque je compile de grosses applis comme RustC ou Firefox sur mes vieux PC qui ont seulement 2 Go de RAM). Dans ce cas-là, même conseil que d'habitude : attache une console à ton PI ce qui te permettra d'avoir les cris du kernel lorsque ton OS commence à partir en roubignoles et tu peux aussi virer le "quiet" des options kernel pour le rendre plus verbeux. Alternativement, tu peux aussi virer la mire de chargement pour voir les messages de la console mais c'est beaucoup moins pratique qu'avoir une vraie console attachée.
Message par Artemus24 » ven. 6 janv. 2023 13:10
Salut Destroyedlolo.
Merci pour tes voeux. :D
Bonne année, bonne santé, mes meilleurs voeux pour 2023, à ta famille et à tes proches.
Destroyedlolo a écrit :Après, j'ai cru comprendre que tu n'as "que" 512Go de RAM sur ce PI3 : c'est vrai que c'est limite suivante le DE qu'il est utilisé (et Ubuntu ne fait JAMAIS les bons choix de ce coté).
Oui, ma Raspberry Pi 3A+ ne possède que 512Go de RAM et un seul port USB.
Pourquoi me parle-tu de Ubuntu ? Je suis sous Raspberry Pi OS Bullseye.
Quand j'utilise mon disque SSD Western Digital Green 120Go qui est sous Buster, je n'ai aucun problème de performance avec ma RPi 3A+. Bizarre, non ?
Destroyedlolo a écrit :Si c'est après le boot, t'as clairement un process qui bouffe beaucoup trop de mémoire
C'est après le boot et je n'ai pas attendu de retrouver une acalmie pour afficher ces résultats.
Destroyedlolo a écrit :Le plus simple est évidemment de passer sur un vrai OS adapté a ta config.
Je suis dans un contexte un peu particulier. J'utilise indifféremment mes RPi 4B/8GB, RPi 3B+, RPi 3A+, RPi 2B, RPi ZERO avec mon disque Maxtor sous bullseye. Quand mon disque Maxtor était sous Buster, je n'avais aucun problème.
Le problème que j'ai rencontré ne concerne que RPi 3A+ et l'installation de la partition swap a résolu mon problème de fluidité.
Sous RPi 4B/8GB, je n'ai aucun problème, et le buffer du swap est continuellement à zéro.
Dois-je comprendre Bullseye est un gros consommateur de la RAM ?
Destroyedlolo a écrit :Sinon, selon ce que tu veux faire, est-ce que X est vraiment nécessaire ?
A 99% de mon temps, je fais que de la ligne commande. J'utilise très peu, mais ça m'arrive d'accéder au bureau de la Raspberry Pi.
Destroyedlolo a écrit :Enfin, le fait que sans fichier swap, tu n'arrives même plus a t'y logger indique clairement que le système est soit totalement planté, soit tourne en boucle pour essayer de libérer de la mémoire
Ce n'est pas évident quand tu ne sais pas où chercher. Après observation de la consommation des processus par "top", j'ai constaté que j'avais "kworker" et "kswpa0" qui consommaient beaucoup. Ce qui est le plus bizarre, je n'ai aucun problème avec mes RPi ZERO alors qu'elles ont aussi que 512Go de RAM.
Pour poursuivre mes investigations sur les perforances des Raspberry Pi, je vais ouvrir d'autres sujets.
Pour ce sujet, je considère qu'il est résolu.
Artemus24.
Message par destroyedlolo » ven. 6 janv. 2023 16:12
Quand j'ai lu "Bullseye", j'ai cru que c'était Ubuntu, my bad.
De toute façon, l'OS de la fondation à la même "qualité" qu'Ubuntu, c'est pourquoi je n'utilise plus ni l'un, ni l'autre :lol:
Je ne sais pas où en est le portage sur les Framboises, mais ARMbian (lui aussi dérivé de Debian) est franchement mieux foutu. Et j'ai vu qu'il y a aussi un portage de TinyCoreLinux : la philosophie est très éloignée des distrib classique mais je suis en train de m'éclaté dessus pour retrouver de l'utilité à de très vielles (et limitée) machines avec en plus l'avantage que l'OS est indestructible. Un autre sujet ...
Malheureusement ... non : il y a eu de gros changements structurels entre les 2 versions et il suffit qu'ils aient changé pour un truc très glouton pour que ce soit le binse. Perso, j'ai des galères avec Gcc sous cette version que je n'ai pas avec les précédentes ou avec Gentoo :cry:
Ben 16x plus de ram.
Hormis mes grosses machines, je n'ai plus X nul part (et surtout pas sur mes SBC) : c'est l'avantage d'Unix, de pouvoir lancer une appli sur une machine pour qu'elle s'affiche ailleurs en utilisant des tunnels X. Évidemment, ce n'est pas valable pour les jeux ou les gros trucs comme une vidéo.
C'est pour ca que je conseille toujours d'avoir une console de connecté quand ca part en roubignole comme ca. Surtout qu'en cas de kernel panic, c'est plus pratique car on peut avoir plus d'historique.
Avec le meme OS ?
Cool, amuse toi bien et A+ ;)
Message par Artemus24 » ven. 6 janv. 2023 17:26
Destroyedlolo a écrit :De toute façon, l'OS de la fondation à la même "qualité" qu'Ubuntu, c'est pourquoi je n'utilise plus ni l'un, ni l'autre :lol:
J'aime bien les Raspberry mais par contre, je déteste le bureau où j'ai continuellement des problèmes.
Je viens encore de perdre la barre du menu et je ne sais pas comment la récupérer.
Sur un disque SSD Western Digital de 250Go où j'ai installé Debian (Bullseye) que j'utilise sur mon ordinateur Asus.
J'utilise Gnome comme bureau et c'est 1000 fois mieux que le bureau merdique de la Raspberry. Au moins, ce bureau est stable.
L'intérêt de la Raspberry, c'est son aspect électronique et système !
Si c'est pour faire du linux, je préfère de loin utiliser Debian (Bullseye) sur mon Asus.
Destroyedlolo a écrit :Malheureusement ... non : il y a eu de gros changements structurels entre les 2 versions et il suffit qu'ils aient changé pour un truc très glouton pour que ce soit le binse.
J'arrive à la même conclusion que toi.
Destroyedlolo a écrit :C'est pour ca que je conseille toujours d'avoir une console de connecté quand ca part en roubignole comme ca. Surtout qu'en cas de kernel panic, c'est plus pratique car on peut avoir plus d'historique.
J'utilise un câble éthernet entre mon Asus et ma Raspberry (si elle dispose d'une prise RJ45).
Même si je n'ai pas de réseau, je peux quand même entrer dans ma Raspberry et avoir une bonne fluidité.
Je me connecte par putty aussi bien avec le wifi qu'avec éthernet. Mon accès par éthernet est ma console connectée.
Sinon, je n'ai pas de moniteur vidéo chez moi, hormis mon téléviseur samsung que j'utilise rarement en tant que console.
Destroyedlolo a écrit :Avec le meme OS ?
Oui, avec l'OS Bullseye qui est installé sur mon disque Maxtor.
C'est pourquoi, je dis que c'est bizarre ce comportement que je ne rencontre qu'avec ma RPi 3A+ et pas avec mes RPi ZERO.
Certainement une différence de comportement dans le firmware de mes Raspberry Pi.
Artemus24.
Message par destroyedlolo » ven. 6 janv. 2023 21:23
Je parlais de la console qui sort par l'Uart.
Peut etre.
