wiringPiSetup: Must be root. (Did you forget sudo?)
DJERO
Message par DJERO » sam. 18 févr. 2017 12:43
Pour pouvoir mettre en place ce projet (http://ouiaremakers.com/posts/tutoriel- ... -ecran-lcd)
J'ai besoin d'utiliser les librairies WiringPI et py-gaugette
Pour wiringPy
J'ai procédé à l'installation qui n'a posée aucun problème, compilé le truc et exécuté les commandes suivantes pour tester le fonctionnement (via le terminal raspian) : gpio -v et gpio readall.
Voici les retours :
pi@raspberrypi:~ $ gpio -v
gpio version: 2.38
Copyright (c) 2012-2017 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Raspberry Pi Details:
Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Sony
* Device tree is enabled.
*--> Raspberry Pi 2 Model B Rev 1.1
* This Raspberry Pi supports user-level GPIO access.
pi@raspberrypi:~ $ gpio readall
+-----+-----+---------+------+---+---Pi 2---+---+------+---------+-----+-----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | ALT0 | 1 | 3 || 4 | | | 5v | | |
| 3 | 9 | SCL.1 | ALT0 | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 1 | 7 || 8 | 1 | ALT0 | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 1 | ALT0 | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | IN | 0 | 11 || 12 | 1 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 0 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 1 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | IN | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | IN | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | IN | 0 | 23 || 24 | 1 | IN | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | IN | CE1 | 11 | 7 |
| 0 | 30 | SDA.0 | IN | 1 | 27 || 28 | 1 | IN | SCL.0 | 31 | 1 |
| 5 | 21 | GPIO.21 | IN | 1 | 29 || 30 | | | 0v | | |
| 6 | 22 | GPIO.22 | IN | 1 | 31 || 32 | 0 | IN | GPIO.26 | 26 | 12 |
| 13 | 23 | GPIO.23 | IN | 0 | 33 || 34 | | | 0v | | |
| 19 | 24 | GPIO.24 | IN | 0 | 35 || 36 | 0 | IN | GPIO.27 | 27 | 16 |
| 26 | 25 | GPIO.25 | IN | 0 | 37 || 38 | 0 | IN | GPIO.28 | 28 | 20 |
| | | 0v | | | 39 || 40 | 0 | IN | GPIO.29 | 29 | 21 |
Jusque là pas de problème.
Pour la librairie gaugette-py je l'ai installée comme ça :
git clone git://github.com/guyc/py-gaugette.git
cd py-gaugette
python setup.py install
Rien de particulier à signaler
Par contre, lorsque je souhaite faire des tests via les samples gaugette-py fournis voici les message d'erreur renvoyé (code: rotary_test.py executé depuis Geany) :
Impossible de lancer quoi que ce soit toujours le même message :(
Avez vous une idée ? Ais-je raté un truc ou installé une libraire à un mauvais endroit ?
Merci pour votre aide
Re: wiringPiSetup: Must be root. (Did you forget sudo?)
Message par domi » sam. 18 févr. 2017 13:39
As tu tenté de lancer ta commande avec sudo ?
DJERO
Message par DJERO » sam. 18 févr. 2017 18:02
absolument, voici le retour :
pi@raspberrypi:~/py-gaugette/samples $ sudo python rotary_test.py
wiringPiSetup*: You must only call this once per program run. This is a fatal error. Please fix your code.
Je suis étonné, car je n'ai rien modifié au code rotary_test.py hormis les pin utilisé pour mon montage.
Rencontrez vous le même problème avec les exemples gaugette ?
D'autre part, y a t-il un moyen d’exécuter les scripts depuis Geany avec sudo ?
Du coup je ne sais pas trop ou chercher :?:
LeBorgne
Message par LeBorgne » sam. 18 févr. 2017 18:59
Je suppose que la ou les librairies ont étés appelés plusieurs fois dans la session cela provoquant une errerur .
Il faut la décharger de la même à la fin du programme
