Bonjour à tous
En ce qui concerne ma configuration :
- Raspberry pi 3
- Raspbian Stretch 9
Donc voilà le résultat de la commande que j'exécute :
Et voici le résultat, après avoir fini de télécharger le fichier "wxPython-4.0.3tar.xz"
Exception:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 353, in run
wb.build(autobuilding=True)
File "/usr/lib/python2.7/dist-packages/pip/wheel.py", line 749, in build
- Raspberry pi 3
self.requirement_set.prepare_files(self.finder)
File "/usr/lib/python2.7/dist-packages/pip/req/req_set.py", line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File "/usr/lib/python2.7/dist-packages/pip/req/req_set.py", line 620, in _prepare_file
session=self.session, hashes=hashes)
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 821, in unpack_url
hashes=hashes
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 659, in unpack_http_url
hashes)
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 882, in _download_http_url
_download_url(resp, link, content_file, hashes)
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 603, in _download_url
hashes.check_against_chunks(downloaded_chunks)
File "/usr/lib/python2.7/dist-packages/pip/utils/hashes.py", line 46, in check_against_chunks
for chunk in chunks:
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 571, in written_chunks
File "/usr/lib/python2.7/dist-packages/pip/utils/ui.py", line 139, in iter
for x in it:
File "/usr/lib/python2.7/dist-packages/pip/download.py", line 560, in resp_read
decode_content=False):
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/response.py", line 432, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/response.py", line 380, in read
data = self._fp.read(amt)
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 63, in read
self._close()
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 50, in _close
self.__callback(self.__buf.getvalue())
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/controller.py", line 275, in cache_response
self.serializer.dumps(request, response, body=body),
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py", line 87, in dumps
).encode("utf8"),
MemoryError
D'après ce que j'ai pu lire sur le site officiel c'est de cette façon qu'il faut procéder... Donc je vous donne aussi toutes les pages (méthodes) que j'ai testées :
1.
https://stackoverflow.com/questions/447 ... pberrypi3#
2.
https://wiki.wxpython.org/BuildWxPythonOnRaspberryPi
3.
https://wxpython.org/blog/2017-08-17-bu ... index.html
... etc.
Franchement, je commence à me demander si cela est réellement possible de l'installer... Je suis bloqué du coup pour le développement de mon petit projet... Car Tkinter est vraiment plus fastidieux que wxPython. Et c'est une vraie galère pour créer des GUI avec.
En espérant que j'ai été assez clair, et que vous possèdés assez d'infos...
