probleme installe fail2ban
piman33
Message par piman33 » sam. 29 sept. 2018 10:22
j ai essayer d installer fail2ban mais pendant l installation j ai eu une erreur
pi@raspberrypi:~ $ sudo apt-get install fail2ban
Reading package lists... Done
Building dependency tree
Reading state information... Done
fail2ban is already the newest version (0.9.6-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up fail2ban (0.9.6-2) ...
Job for fail2ban.service failed because the control process exited with error co               de.
See "systemctl status fail2ban.service" and "journalctl -xe" for details.
invoke-rc.d: initscript fail2ban, action "start" failed.
● fail2ban.service - Fail2Ban Service
   Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; vendor preset:                enabled)
   Active: activating (auto-restart) (Result: exit-code) since Sat 2018-09-29 08               :16:02 UTC; 31ms ago
     Docs: man:fail2ban(1)
  Process: 7696 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status               =255)
Sep 29 08:16:02 raspberrypi systemd[1]: fail2ban.service: Unit entered faile…te.
Sep 29 08:16:02 raspberrypi systemd[1]: fail2ban.service: Failed with result…e'.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: error processing package fail2ban (--configure):
 subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
 fail2ban
E: Sub-process /usr/bin/dpkg returned an error code (1)
j ai fait :
sudo apt-get remove fail2ban
sudo apt-get purge fail2ban
et une nouvelle installe mais toujours le meme message d erreur
lann
Re: probleme installe fail2ban
Message par lann » dim. 30 sept. 2018 10:34
Essayes de faire :
sudo apt-get update
sudo ap-get upgrade
piman33
Message par piman33 » dim. 30 sept. 2018 17:59
ca change rien
Message par Artemus24 » mar. 2 oct. 2018 09:33
Salut piman33.
Cela vous arrive de lire le compte-rendu du traitement ?
systemctl status failban.service
Vous aurez la raison de votre plantage.
cbalo
Message par cbalo » mer. 28 août 2019 19:14
Suis d'accord.
En plus, l'installation ne plante pas, seul le démarrage du service, lancé automatiquement à la fin de l'installe plante.
Moi je laisserai l'installation se faire puis je chercherai pourquoi le service ne démarre pas.
systemctl offre des tas de possibilité pour en savoir plus.
Il y a le classique systemctl status fail2ban.service mais qui est peu bavard
il y a comme le dit la log journalctl -xe mais c'est pas très bavard non plus
Alors qu'il y a journalctl -u faile2ban.service qui lui va bien causer.
Et en plus il y a le fichier de log de fail2ban qui est là où se trouvent tous les fichiers de log de tous les services sous Linux à savoir : dans /var/log/
Petite parenthèse concernant fail2ban :
Je me demande bien pourquoi le programme d'installation tente de démarrer le service.
En effet, dans la doc fail2ban il est bien spécifié qu'il faut d'abord spécifier les filtres et les prisons qu'on désire mettre en place avant de lancer le service.
En plus fail2ban est très dépendant des versions de gestionnaire de service et de pare-feu installés hors en ce moment, rc.d existent encore et systemd est de plus en plus présent et iptables existe toujours mais firewalld prend la relève petit à petit.
Bref fail2ban doit pouvoir gérer un système exploitant rc.d / iptables ou systemd / iptables ou systemd/firewalld ça fait beaucoup de if d'où la nécessité de mettre la main dans le cambouis pour qu'il fonctionne
