RPI Robot: Easily Build Your Custom Robot with Raspberry Pi
OpenELAB
Message par OpenELAB » lun. 4 nov. 2024 05:11
:D RPI Robot is a robot project built on the Raspberry Pi platform, designed to provide a simple, feature-rich, and expandable platform for robot enthusiasts. Created by developer rossning92 and published as an open-source project on GitHub, RPI Robot has gained attention for its user-friendliness, powerful functionality, and high extensibility. This article will introduce the core components, features, and usage of RPI Robot, guiding you through the world of Raspberry Pi robot development.
:D RPI Robot Project Structure
The RPI Robot project features a well-organized code structure, making it easy for developers to navigate and modify. Below are the main components of the project:
1. device.py
This module defines the interface for interacting with the robot hardware, including functions for controlling motors and reading sensor data.
2. main.py
The main program is responsible for starting the web server, processing user commands, and calling functions from device.py to control the robot.
3. twowheel.py
This script provides the control methods for a two-wheel drive robot chassis, enabling smooth movement and control.
4. install.sh
A script for installing necessary dependencies is required to run the project smoothly.
5. rpi-robot.sh
A startup script is used to launch the robot service, ensuring the system initializes correctly for operation.
:D Function Overview
The RPI Robot project offers the following key features:
Remote Control:
Users can control the robot remotely through a web interface, accessible via a smartphone or computer browser.
Face Tracking:
The robot is equipped with a camera to detect and track faces, automatically adjusting its direction to follow the target.
How to Use
1. Install Dependencies:
First, you need to install the required dependencies on your Raspberry Pi. Run the following command:
>>copy the code in: https://openelab.io/blogs/learn/rpi-rob ... 80b9&_ss=r
The script will automatically install Python, TensorFlow, Flask, and other essential libraries, including OpenCV for image processing.
2. Start the Robot:
After the installation is complete, use the following command to start the robot:
3. Remote Control:
Once the robot is running, access the web interface by visiting: http://<your rasberry pi IP address>:5000
From there, you can control the robot remotely using a web browser on your smartphone or computer.
:D Face Tracking Feature
The RPI Robot uses TensorFlow and OpenCV to implement its face tracking functionality. The camera captures images, which are sent to the server for face detection and localization. Based on the detection results, the robot adjusts its direction to keep the camera aligned with the face at all times.
This feature enables the robot to track faces dynamically, providing a seamless interactive experience.
:D Project Features
The RPI Robot project offers the following features:
Beginner-Friendly:
The project is easy to understand, making it accessible even for those with no prior experience in robotics development.
Powerful Functionality:
It provides practical features such as remote control and face tracking, laying a solid foundation for further development.
High Extensibility:
With a clear code structure, developers can easily add new features as needed.
:D Application Scenarios
The RPI Robot project can be used in various robotics applications, including:
Education:
Ideal for teaching robotics, helping students learn robot control and programming skills.
Entertainment:
Build a face-tracking robot to interact with people and provide entertainment.
Security:
Use the robot as an intelligent patrol robot with face recognition to enhance security.
The RPI Robot project serves as a great entry-level platform for Raspberry Pi robotics development. Through this project, you can learn key skills like robot control, image processing, and web development, while building a robot of your own.
more details:https://openelab.io/blogs/learn/rpi-rob ... 80b9&_ss=r
Re: RPI Robot: Easily Build Your Custom Robot with Raspberry Pi
Message par domi » lun. 4 nov. 2024 10:35
Bonjour et merci d'utiliser le français pour échanger.
Je verrouille ce sujet.
