Raspbian trixie
knasson
Raspbian trixie
Message par knasson » sam. 20 déc. 2025 14:21
bonjour,
Je viens vous voir car je suis bien embété par mon Raspbian trixie.
-le materiel c'est un raspberry pi 4 32 bits
-j'etais avant en version Bookworm
-j'ai installé une mise a jour de domoticz 2025-2
les constatations:
si je fais lsb_release -a
j'obtiens :
root@raspberrypi:/home/kan# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 13 (trixie)
Release: 13
Codename: trixie
lorsque je veux faire apt update j'obtiens ca
root@raspberrypi:/home/kan# apt update
Ign:1 http://phoscon.de/apt/deconz trixie InRelease
Err:2 http://phoscon.de/apt/deconz trixie Release
  404  Not Found [IP: 144.76.96.194 80]
Get:3 http://security.debian.org/debian-security trixie-security InRelease [43.4 kB]
Get:4 http://raspbian.raspberrypi.org/raspbian trixie InRelease [15.0 kB]
Get:5 http://archive.raspberrypi.org/debian trixie InRelease [54.8 kB]
Ign:6 https://download.docker.com/linux/raspbian trixie InRelease
Err:7 https://download.docker.com/linux/raspbian trixie Release
  404  Not Found [IP: 2600:9000:218f:6200:3:db06:4200:93a1 443]
Ign:8 http://deb.debian.org trixie-updates InRelease
Err:9 http://deb.debian.org trixie-updates Release
  404  Not Found [IP: 2a04:4e42:6a::644 80]
Get:10 http://raspbian.raspberrypi.org/raspbian trixie/main armhf Packages [15.7 MB]
Err:3 http://security.debian.org/debian-security trixie-security InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BDE6D2B9216EC7A8 NO_PUBKEY 8E9F831205B4BA95
Reading package lists... Done
E: The repository 'http://phoscon.de/apt/deconz trixie Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'https://download.docker.com/linux/raspbian trixie Release' does not have a Release file.
W: http://raspbian.raspberrypi.org/raspbian/dists/trixie/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
E: The repository 'http://deb.debian.org trixie-updates Release' does not have a Release file.
W: GPG error: http://security.debian.org/debian-security trixie-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BDE6D2B9216EC7A8 NO_PUBKEY 8E9F831205B4BA95
E: The repository 'http://security.debian.org/debian-security trixie-security InRelease' is not signed.
W: http://archive.raspberrypi.org/debian/dists/trixie/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
root@raspberrypi:/home/kan# E: The repository 'http://phoscon.de/apt/deconz trixie Release' does not have a Release file.
roo
je ne comprends pas ce qui se passe quelqu'un peut il m'eclairer?
ou me donner quelques pistes pour solutionner ça
contenu de mon fichier /etc/apt/sources.list
deb http://raspbian.raspberrypi.org/raspbian/ trixie main contrib non-free rpi
deb http://security.debian.org/debian-security trixie-security main contrib non-free rpi
deb http://deb.debian.org trixie-updates main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
d'avance merci
Retourner vers « Raspbian »
