Raspbian trixie
knasson
Raspbian trixie
Message par knasson » sam. 20 déc. 2025 14:21
bonjour,
Je viens vous voir car je suis bien embété par mon Raspbian trixie.
-le materiel c'est un raspberry pi 4 32 bits
-j'etais avant en version Bookworm
-j'ai installé une mise a jour de domoticz 2025-2
les constatations:
si je fais lsb_release -a
j'obtiens :
root@raspberrypi:/home/kan# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 13 (trixie)
Release: 13
Codename: trixie
lorsque je veux faire apt update j'obtiens ca
root@raspberrypi:/home/kan# apt update
Ign:1 http://phoscon.de/apt/deconz trixie InRelease
Err:2 http://phoscon.de/apt/deconz trixie Release
  404  Not Found [IP: 144.76.96.194 80]
Get:3 http://security.debian.org/debian-security trixie-security InRelease [43.4 kB]
Get:4 http://raspbian.raspberrypi.org/raspbian trixie InRelease [15.0 kB]
Get:5 http://archive.raspberrypi.org/debian trixie InRelease [54.8 kB]
Ign:6 https://download.docker.com/linux/raspbian trixie InRelease
Err:7 https://download.docker.com/linux/raspbian trixie Release
  404  Not Found [IP: 2600:9000:218f:6200:3:db06:4200:93a1 443]
Ign:8 http://deb.debian.org trixie-updates InRelease
Err:9 http://deb.debian.org trixie-updates Release
  404  Not Found [IP: 2a04:4e42:6a::644 80]
Get:10 http://raspbian.raspberrypi.org/raspbian trixie/main armhf Packages [15.7 MB]
Err:3 http://security.debian.org/debian-security trixie-security InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BDE6D2B9216EC7A8 NO_PUBKEY 8E9F831205B4BA95
Reading package lists... Done
E: The repository 'http://phoscon.de/apt/deconz trixie Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'https://download.docker.com/linux/raspbian trixie Release' does not have a Release file.
W: http://raspbian.raspberrypi.org/raspbian/dists/trixie/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
E: The repository 'http://deb.debian.org trixie-updates Release' does not have a Release file.
W: GPG error: http://security.debian.org/debian-security trixie-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BDE6D2B9216EC7A8 NO_PUBKEY 8E9F831205B4BA95
E: The repository 'http://security.debian.org/debian-security trixie-security InRelease' is not signed.
W: http://archive.raspberrypi.org/debian/dists/trixie/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
root@raspberrypi:/home/kan# E: The repository 'http://phoscon.de/apt/deconz trixie Release' does not have a Release file.
roo
je ne comprends pas ce qui se passe quelqu'un peut il m'eclairer?
ou me donner quelques pistes pour solutionner ça
contenu de mon fichier /etc/apt/sources.list
deb http://raspbian.raspberrypi.org/raspbian/ trixie main contrib non-free rpi
deb http://security.debian.org/debian-security trixie-security main contrib non-free rpi
deb http://deb.debian.org trixie-updates main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
d'avance merci
maxty01
Re: Raspbian trixie
Message par maxty01 » ven. 26 déc. 2025 11:06
Bonjour @knasson,
Le premier point intéressant est que "phoscon.de" ne semble pas faire partie de ton fichier /etc/apt/sources.list.
Peux-tu nous dire s'il existe d'autres fichiers de configuration apt dans le dossier /etc/apt/sources.list.d/, si oui, peux-tu nous donner le nom et le contenu du/des fichiers ?
Le second point est que APT donne des 404, j'en déduis qu'il a accès à internet sans problème DNS, cependant, il fait aussi des erreurs de certificat et signature.
De part ces éléments, j'aurai tendance à émettre l’hypothèse que la raspbian 13 - trixie - serait "ancienne", ou du moins, pas à jour, et que suite à cela le système ne sait plus se mettre à jours.
C'est hypothétique mais peu probable, mais pas impossible.
Concernant l'IPv6, le temps de l'investigation, je préconise de le désactiver afin de forcer le système en IPv4.
De quand date la dernière mise à jour du système (apt update + apt upgrade) ?
Si tu est au début de ton projet, sans trop de configuration lourde, je préconiserai une réinstallation du système avec la dernière image de raspbian la plus à jour possible. mais à de lire, je doute que tu sois dans ce cas.
Un autre solution, plus complexe, serait de refaire le keyring de tous les repos.
Je te laisse avec ces indications/hypothèses pour l'instant pour ne pas t'embrouiller plus pour le moment.
bàt,
knasson
Re: Raspbian trixie
Message par knasson » sam. 27 déc. 2025 22:16
bonsoir,
Merci pour m'avoir lu ...
IPV6 limiter a ipV4 comment fait on ça?
Sinon pour le reste j'ai installe Trixie en changeant "bookworm" par "trixie" dans le sources.list et le sources.list.d
et en faisant un apt full-upgrade
maintenant je me retrouve avec un trixie qui me donne des erreurs de sources sans clé.et qui est incapable de faire un update sans erreur.
Nota Bene le logiciel "domoticz" qui tourne dessus fonctionne parfaitement.
refaire le "keyrings" faut que je me documente car je n'ai jamais fait ca.
reinstaller Trixie pourquoi pas mais comment fait on ca sans perdre tous les logiciels qui sont deja installés?
maxty01
Re: Raspbian trixie
Message par maxty01 » lun. 29 déc. 2025 10:49
Pour désactiver l'IPv6, voici un exemple, d'autres articles sur le net parle de ce sujet :
https://www.howtoraspberry.com/2020/04/ ... pberry-pi/
Ceci m'intrigue :
Quelles techniques as-tu utilisé ?
Quel howto as-tu suivi ?
Quelles commandes ont été utilisées en plus du «apt full-upgrade» ?
Je considère que refaire un keyring, est un excercice qui demande de grande connaissance du système de package de debian.
Ce n'est donc pas à la portée de toute le monde.
Un réinstallation veut dire que tout sera supprimé afin d'installer à nouveau raspbian 13.
A moins d'effectuer une copie des fichier important pour facilité la réinstallation de tous les soft.
bàt,
Retourner vers « Raspbian »
